2nd gen 5sfe vs 3rd gen 5sfe., Camshaft |
Apr 20, 2014 - 11:12 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
I was wandering if the 2nd gen 5sfe camshaft are any different from the 3rd gen camshaft? I was told they're slightly more aggressive. Also are they interchangeable parts?
This post has been edited by ILoveMySilly97: Apr 20, 2014 - 11:55 PM -------------------- |
Apr 21, 2014 - 12:46 AM |
Yes and yes. For whatever reason, probably emissions, they're not as aggressive in the 6th gen. Similar thing happened with the ST when it became OBDII, a more restrictive intake lost 5 hp. Is it worth the trouble, probably not unless you're sending them off to be ground. Power to weight ratio goes from 19.85 to 19.1, so meh... Now if you could get 20 or more from doing cams...
Apr 21, 2014 - 1:32 AM |
Yes and yes. For whatever reason, probably emissions, they're not as aggressive in the 6th gen. Similar thing happened with the ST when it became OBDII, a more restrictive intake lost 5 hp. Is it worth the trouble, probably not unless you're sending them off to be ground. Power to weight ratio goes from 19.85 to 19.1, so meh... Now if you could get 20 or more from doing cams... I see. thanks. -------------------- |
Lo-Fi Version | Time is now: December 1st, 2024 - 3:07 PM |
