Oil leak, Weird oil leak - 5SFE stock |
Apr 27, 2014 - 4:59 PM |
Enthusiast Joined May 2, '06 From Nevada Currently Offline Reputation: 0 (0%) |
Weird - cannot pinpoint the source. Pretty serious. Oil gets on the tulip behind the inner passenger side drive axle boot, but not on the boot itself.
Then thrown on the cross member behind. BUT - if it were the crankshaft seal, oil pump seal - it would get on the boot first, since it is directly on the way. But the boot is dry - and the cylinder it is attached to is wet. And the pump area is dry... If it were the camshaft seal - I do not see how is could avoid the power steering pump or other areas for the same reason. But the pump is dry too. Valve cover gasket is ruled out! - just replaced it, no difference. My distrubutor ring is leaking - but it is very far away, and has been leaking for years - minor. Which leaves? Oil pan gasket? But there is no pressure there to throw oil that far and that much. I do not believe head gasket could leak in such a narrow fashion, and 5SFE is not known for it. Any ideas? Thanks! |
Apr 28, 2014 - 3:12 PM |
there really isnt a gasket on the oil pan, its a silicone type gasket. its possible that it has failed, and you are right its not really pressurized but the turbulence in there can send oil flying. can you post pictures? clean the area really well, then look to see where the leak is coming from.
Apr 28, 2014 - 4:16 PM |
Enthusiast Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
I always put my money on the oil pump seals every time. would be a good idea to reseal it when ur doing ur water pump timing belt, etc.
Apr 28, 2014 - 11:02 PM |
Oil pan gasket, the wind will throw it up the backside of the engine. The crankshaft is spinning right next to the gasket so plenty of oil gets slung on it. And between the blow-by of the piston rings and the action of the pistons flying up and down, there is a slightly oscillating vacuum/pressurization that will blow oil out.
Oil pump gasket leak will gush large amounts of oil out every time the engine is running. Like quarts every time you drive it. |
Apr 30, 2014 - 2:53 PM |
oil pump seal seeps all the time, leaks down the cover and falls on the axle while ur driving and makes a mess. just loosen te cover and look inside
Lo-Fi Version | Time is now: January 10th, 2025 - 9:25 AM |
