> 3SGTE swap - fuel pump relay/resistor
post May 1, 2014 - 8:50 AM
digs
Joined Aug 2, '11
From southampton
I kinda have used the search, but was after an answer for an idot if anyone can help.....
3SFTE is out (after blowing cylinder 3.....) and 3sgte rev 3 going in! A mechanic, not my self, is doing the swap, and has encountered the fuel pump issue...i.e. it won't work!
He knows the faff has a relay for it's fuel pump, which my 3sfe lacks. Assuming the 5sfe is the same, can anyone explain simply (to me) how this is sorted out ?
Using rev 3 3SGTE, with rev 3 loom, and have the faff fuel pump relay. Not sure where the 3sfe fuel pump is coming off, guessing same as 5sfe ?
Thanks for any help at all! Everything is looking brilliant!
post May 1, 2014 - 9:37 AM
digs
Joined Aug 2, '11
From southampton
should add, mechanic has a plan, but looking also at what other have done - actual fuel pump is aftermarket walbro equiv.
post May 1, 2014 - 1:37 PM
Malek
Joined Jan 26, '09
From Los Angeles
This should help..
http://www.6gc.net/forums/index.php?showtopic=65840
and if not..Here's another..
http://www.6gc.net/forums/index.php?showtopic=82196
Idk what the difference in wiring is between 5sfe and 3sfe (if any)..
Good luck!
post May 1, 2014 - 1:44 PM
digs
Joined Aug 2, '11
From southampton
QUOTE (Malek @ May 1, 2014 - 2:37 PM) *
This should help..
Good luck!
Awesome, first link looks good!
post May 1, 2014 - 3:57 PM
mkernz22
Joined May 10, '10
From MA
you need to get a walboro 255lph fuel pump for the 3sgte
post May 1, 2014 - 4:14 PM
digs
Joined Aug 2, '11
From southampton
QUOTE (mkernz22 @ May 1, 2014 - 4:57 PM) *
Cheers smile.gif Have one of these fitted http://www.tuningdevelopments.co.uk/produc...products_id=201
This post has been edited by digs: May 1, 2014 - 4:27 PM
Lo-Fi Version Time is now: December 1st, 2024 - 5:27 PM
