Distributor housing seal leak, Distributor housing seal leak |
May 7, 2014 - 3:41 PM |
Enthusiast Joined May 2, '06 From Nevada Currently Offline Reputation: 0 (0%) |
Any tips how to seal the distributor housing? I placed an OEM O-ring (on the part going into under the valve cover), did everything as the book says - leaking!
Any proven advise? Non-OEM? Put something on it? Anything? Thanks! |
May 7, 2014 - 4:53 PM |
you replaced the big O-ring that goes around the shaft of the dizzy that inserts into the head? thats all thats needed
May 7, 2014 - 11:34 PM |
There is supposed to be some FIPG around the corners of the halfmoon hump where the valve cover gasket touches the distributor collar. I think FIPG actually goes between the collar and the head as well.
I would suggest installing the distributor with the valve cover removed and the two bolts on the collar/bracket loosened, that way you know you arent pinching the oring while inserting the distributor. |
Lo-Fi Version | Time is now: November 27th, 2024 - 3:58 AM |
