Exhaust question, Dual exhaust |
May 9, 2014 - 8:59 AM |
Enthusiast Joined Jan 13, '12 From Georgia Currently Offline Reputation: 3 (100%) |
Wondering what you guys think. I have 3 different ideas I'm rolling around in my head.
Split from 1to2 using the Cat Split from 1to2 using the resonator Running one pipe to a resonator tucked behind the rear bumper that splits to two mufflers Looking for input on which will yield the best results as far as gain, flow and sound. I'm going to do it one way or the other I just don't know a whole lot about exhaust yet and what will effect sound and performance other than what I've read here Thanks in advance -------------------- 97 Celica GT liftback DD/ project
96 corolla back up DD |
May 9, 2014 - 10:22 AM |
option 3 is the most restrictive more than likely
option 2 with the resontator would probably be the best. I split my exhaust into 2 at the rear cross member when I did it. a) I wouldn't use anything larger than 2" at the most for the dual pipe section. 1.5" pipe would do fine b) sound depends on Cat, resonators and type of muffler so nobody can really input on how loud it will be or sound like performance......probably won't be able to tell any differences except for throttle response maybe. This post has been edited by playr158: May 9, 2014 - 10:24 AM |
May 9, 2014 - 10:50 AM |
Do you have any pics of your set up profile pics are old. And don't do any justice to your car
May 9, 2014 - 12:49 PM |
Uneven length headers could alter the sound of your exhaust to a V6 or even V8 sound. There probably arent any options on our motors other than custom made for this though.
For maximum performance and sound you should run true dual exhaust all the way. You will need two seperate headers fed by two cylinders a piece and or a header that has two collectors. Then I'd suggest trying to fit a second exhaust pipe from the collector back to the tailpipe. Not sure if you could just nab a exhaust from a junkyard celica and run it next to the existing pipe or if you'd need a custom job. Either increasing the size of the entire pipe or having two seperate pipes will increase performance. A cat-back or muffler-back solution wouldnt alter the performance and probably wont sound drastically different. You could always get an electric cutout l, that would sound pretty awesome, give you a slight performance boost and you could turn it off with the flip of a switch. |
Lo-Fi Version | Time is now: November 30th, 2024 - 9:53 AM |
