> steering wheel shakes?
post May 13, 2014 - 8:04 PM
bdog_v
Joined Jan 17, '06
From Wisconsin
Hi guys quick question here for ya. I have 94 celica gt. I have a very slight to the point you can't notice at 60mph steering wheel wiggle back and forth. Then when I get on the interstate at 70-75 mph it is more noticeable but not horrible I could live with it I just would like it to be rock steady at 70mph on long trips.... Any things I should look for ? I have new polyurethane mounts in both wishbones so I am not sure what else to check. I can tell you this....
-I do have 17" wheels on close to 1" spacers for a couple of years now, camber has been adjusted so I don't burn off the inside edge of the tires like I originally did when I first added the spacers. Tires should be balanced correctly as I have 2 sets winter tires and summer that both do the same thing.
-Are there any other rubber mounts that need to be checked that could cause this?
-Any worn parts that could cause it?
Any ideas???
Thanks....
Brandon
post May 13, 2014 - 10:33 PM
blockustomz
Joined Nov 18, '13
From FL
Motor mounts could be bad.. Heard of bad cv joints giving shake.. and of course ball joints, tie rods, & wheel bearings could be shot with the 1" spacers u got on..
At first I was thinking wheels need balance or spacers but if other wheels do the same thing then it can't be..
I'm also assuming you took off the spacers when the other wheels are on. If not give that a try..
This post has been edited by blockustomz: May 13, 2014 - 10:35 PM
@floordauto
post May 13, 2014 - 11:59 PM
Box
Joined Feb 23, '12
From Warrior, AL
Lift the front of the car and grab onto each front wheel and try to wiggle the wheels from top to bottom and side to side. Check for looseness and odd noises.
2001 Miata LS 5-speed
post May 14, 2014 - 2:12 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Alignment probably needs to be redone because of the cambe adjustment you made. I adjusted mine to have more camber jn the front and it caused my steering to shake ay high speeds. Going to take it in for an alignment soon. Should solve the problem.
post May 14, 2014 - 7:34 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
How old are your tires and what is their weight rating? Also, are your spacers hub centric/do your wheels have hub centering rings?
post May 14, 2014 - 9:24 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
could also be something as simple as a bent wheel/out of balance wheel
My Celica!
post Jun 11, 2014 - 5:23 AM
jazzamoff1
Joined Jun 9, '14
From New Zealand
Had the same thing in mine. But after a while it got VERY bad. Ended up being dry CV joints. Pulled the CV boots back and squeezed a grease pack into the inner CV and another in the outter and pulled the boots back. Prick of a job but did the trick. last 18 months with no issues. A local garage may do the job for about an hours labour.
Lo-Fi Version Time is now: February 16th, 2025 - 5:10 PM
