> Distributor rebuilt - INNER oil seal replacement, Who has it done?
post May 25, 2014 - 3:27 PM
valerit1
Joined May 2, '06
From Nevada
Ok, a kit is available. I got stuck on the pin removal. Which side to strike - they both look the same thickness? And it does not come out, does not move at all! How to do it? Please share in detail this part of the procedure. The rest seems to quite simple.
Thanks!
post May 26, 2014 - 9:10 AM
Getting that pin out is a huge pain. I don't think it matters which side you strike it on. You will need a good quality punch and something like a 5lb hammer, and a lot of patience. Doesn't hurt to spray some wd40 in there too.
post May 26, 2014 - 10:52 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (valerit1 @ May 25, 2014 - 3:27 PM) *
Thanks!
If all else fails a machine shop will gladly press it out for you. I'd try using an icepick and a hammer.
post May 29, 2014 - 6:39 PM
valerit1
Joined May 2, '06
From Nevada
What punch size is it? Thanks!
QUOTE (lagos @ May 26, 2014 - 9:10 AM) *
Lo-Fi Version Time is now: April 22nd, 2025 - 4:13 PM
