Enthusiast Joined Jun 10, '14 Currently Offline Reputation: 0 (0%) ![]() |
Hi, I have a 1995 Toyota Celica ST, and I need to replace the Coolant Temperature Switch. I already purchased one from amazon, but even though amazon said it's the right fit it was clearly not compatible when I received it.
This post has been edited by hellocelicas: Jun 11, 2014 - 2:26 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) ![]() |
For most parts I buy online I go to rockauto.com. Many times they even have the factory Toyota brand to choose from and it will cost less than it would at O'Reilly .
Keep in mind there is a difference between the sensor(sender that goes to the gauge, and the sensor that goes to the computer. -------------------- Bust a Deal; Face the Wheel.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) ![]() |
Hi, I have a 1995 Toyota Celica ST, and I need to replace the Coolant Temperature Switch. I already purchased one from amazon, but even though amazon said it's the right fit it was clearly not compatible when I received it. I am attaching an image as reference. ![]() Coolant temperature- Switch = for the fan relays Sender = for the Temp guage on the cluster Sensor = for the ecu and EFI If you were throwing a code, you needed the coolant sensor not the coolant switch. The coolant switch threads into the lower radiator and turns the cooling fans on or off. This post has been edited by Special_Edy: Jun 11, 2014 - 11:15 AM |
Ah, my pic got messed up sorry! It is the sensor/switch that connects to the engine block right where the upper radiator tube hits the engine. I really like buying from amazon, here is the list of options I'm not sure about at Amazon
well you're picking from the same brands whether you get it on amazon or rockauto. just be sure you pick the right motor, the ST is 1.8L and the GT is 2.2L
maybe that's what did? -------------------- Bust a Deal; Face the Wheel.
Hey, when I set my motor type I still get many options and don't know which to choose. Can you like link to 2 or 3 alternatives that will fit my ST, Amazon filter is not perfect and I already made a mistake, hoping someone will help.
Like I said, you need a coolant sensor, it is not the same part as a coolant switch
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
THANKS!!! |
Lo-Fi Version | Time is now: February 21st, 2025 - 5:22 PM |
