> Upgrading to a 3sgte
post Jun 25, 2014 - 11:46 AM
ian0490
Joined Apr 17, '13
From Beaufort, SC
Hopefully I will be upgrading to a 3sgte by next year and need to know what all should be planning to buy for? I got a 94 Celica GT. I'll be buy the Motor
Transmission, ECU, Distributor, Alternator, Complete Intake and Exhaust Manifold, A/C Power Steering Pump, All Brakets and Sensors, Engine Wiring Harness, All required Cables, and Turbo... Other than an upgraded fuel pump (recommendations on that) and pressure gauges for interior, what else should I be purchasing?
post Jun 25, 2014 - 2:01 PM
a lottery ticket.
post Jun 25, 2014 - 6:26 PM
TClifton91
Joined May 13, '14
From Savannah, GA
QUOTE (ian0490 @ Jun 25, 2014 - 11:46 AM) *
Manual boost controller...or an electronic one if your already spending the money.
post Jun 25, 2014 - 6:54 PM
Box
Joined Feb 23, '12
From Warrior, AL
Save some money and just get the complete engine, ECU, and harness. You can't use the transmission that comes with it anyway as it's AWD, the S54 in the GT will work just fine with an upgraded clutch and stock power levels.
2001 Miata LS 5-speed
post Jun 26, 2014 - 12:31 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
yes the AWD trans can be used, it will only cost you a differential and cover plate
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jun 26, 2014 - 2:32 AM
Box
Joined Feb 23, '12
From Warrior, AL
I guess you'd more or less make it an E153 then.
Lo-Fi Version Time is now: December 1st, 2024 - 9:56 PM
