running an alarm with a turbo timer |
Jun 26, 2014 - 10:43 PM |
Enthusiast Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) |
I came across a thread about running a turbo timer with an alarm a while back but I don't remember if that was this forum or one of the other ones. My turbo timer keeps me from arming the alarm until the car shuts off, I tried to bypass this by wiring the timer to only run the engine management instead of straight off of the ignition and it still doesn't arm when the car is running, plus it unlocks the doors when the car shuts off so I can't manually lock it and walk away. I think because I'm using the old injector wires coming off the fuse box to trigger the relays to come on when I turn on the ignition, it back feeds the ignition system through the fuse box. Diode maybe? I would have to buy one.
-------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
Jun 26, 2014 - 11:43 PM |
Enthusiast Joined Aug 2, '06 From bay area Currently Offline Reputation: 21 (100%) |
well my alarm has remote start as well as turbo timing. i can also arm the car while still on. its the clifford 50.5x alarm if you were wondering. been great for all the years that ive had it
Jun 27, 2014 - 1:07 AM |
well my alarm has remote start as well as turbo timing. i can also arm the car while still on. its the clifford 50.5x alarm if you were wondering. been great for all the years that ive had it I just looked it up, it's pretty pricey and I already have an alarm that works. I think I can wire in a diode so it doesn't backfeed the stock fusebox. It isn't much load, everything that is powered is powered by relays, so I don't need a very heavy-duty diode. -------------------- -Jay
Jun 28, 2014 - 9:25 PM |
I looked up the load for the relays and all of them together pull 480 milliamps, which is 5.76 watts on a 12v system. The largest diode I could find was 12v 5w. As clean as it would have looked I would have rather done that, but it goes over the allowed load. Instead I used a relay to break the signal between the factory fusebox and the turbotimer, not as clean, but it gets the job done. It's all good now, the doors unlock when I turn off the key even though the car is still running, the alarm arms when the turbo timer is still counting down, and the doors don't unlock when the timer finally shuts off the engine. It's perfect! Only irritating thing is the car alarm goes off after 10 seconds from the car vibration.
Lo-Fi Version | Time is now: February 13th, 2025 - 3:28 PM |
