Help!! Smoking like its no tomorrow!, I need help to figure out what it is and how to fix it.. |
Jul 31, 2014 - 12:20 AM |
Hmm maybe its different on the 5s and 7a, Im certain I have my old headbolts somewhere around here.
And I could of sworn the cam bolts are 6 sided on the 5s, I rounded one off |
Aug 2, 2014 - 6:32 PM |
Enthusiast Joined Nov 25, '13 From Norway Currently Offline Reputation: 0 (0%) |
Aug 2, 2014 - 11:18 PM |
Enthusiast Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
lol that looks like some good 'ole redneck Cat repair right there.
-------------------- Bust a Deal; Face the Wheel.
Aug 3, 2014 - 3:51 PM |
Aug 3, 2014 - 11:53 PM |
Enthusiast Joined May 10, '14 From Tulsa, OK Currently Offline Reputation: 5 (100%) |
So it is possible to take the engine out without taking the gearbox out. I have the head, intake, exhaust, pistons and rods and oil pan out but would now like to take the block out to check the crank bearings etc.
Aug 4, 2014 - 1:22 PM |
Aug 5, 2014 - 12:12 PM |
Aug 5, 2014 - 1:31 PM |
Hey look, it's facing in the right direction now.
Aug 7, 2014 - 7:26 AM |
I am curious to see how ease the engine will go back and lined up with the Gearbox. Please take some photos of how you will put it back.
thanks |
Aug 10, 2014 - 7:08 PM |
Enthusiast Joined Jan 2, '13 From timothy0 Currently Offline Reputation: 0 (0%) |
Piston ring
This post has been edited by Timothy: Aug 10, 2014 - 7:10 PM |
Aug 11, 2014 - 1:17 AM |
I am curious to see how ease the engine will go back and lined up with the Gearbox. Please take some photos of how you will put it back. thanks Ehm. i Had to take the trany out :S it was mutch easyer to fitt the engine w/ tranny then just the engine whit the trany in place Piston ring What abote them? |
Aug 18, 2014 - 1:02 PM |
need some help again. the car strarts but when i rev it it dies at 3k rpm. any solution ?
This post has been edited by Tort1llaboy: Aug 18, 2014 - 1:04 PM |
Aug 18, 2014 - 2:53 PM |
Fuel issues?
Aug 18, 2014 - 3:19 PM |
Could be something with the MAP sensor, or a matter of timing.
Aug 18, 2014 - 4:37 PM |
it works fine when idle. only when i hit 3k rmp it starts to be the ishue. i have been thinking of both thos things.. but the timing shuld be good.
Aug 18, 2014 - 4:56 PM |
I'd check the MAP and look for any vacuum leaks.
Aug 19, 2014 - 4:44 PM |
culdent find anything wrong whit the MAP sensor. what else can be wrong?
Aug 19, 2014 - 4:48 PM |
I'd take a look at the distributor and ignition coil. I wouldn't think it'd be fuel related since none of that was touched, so it has to be a matter of timing/ignition.
Aug 20, 2014 - 5:00 AM |
It might be the rotor, checked it last week and it had some corotion on it, i cleaned it and put it back.
spoke to a toyota mechanic and he sayd it might be a ground fault. need to check this after work This post has been edited by Tort1llaboy: Aug 20, 2014 - 5:03 AM |
Aug 20, 2014 - 2:12 PM |
Ah yes, grounding points are also important.
Lo-Fi Version | Time is now: November 27th, 2024 - 11:06 AM |
