7 Pages V  < 1 2 3 4 5 > »
> Help!! Smoking like its no tomorrow!, I need help to figure out what it is and how to fix it..
post Jul 10, 2014 - 12:57 PM
msk59
Joined May 10, '14
From Tulsa, OK
I will be starting to re-ring and headwork on my 96 ST. The compression check was not good on cylinder # 1 and 2. The other two were not good either. I did Piston soal twice, one with SeaFoam and second time with MMO. No luck.
Question: Does headbolts require a special socket?
Thanks in advance.
(Sorry to highjack your thread)
post Jul 10, 2014 - 1:11 PM
Tort1llaboy
Joined Nov 25, '13
From Norway
QUOTE (msk59 @ Jul 10, 2014 - 12:57 PM) *
Thanks in advance.
i used a star shaped socket, i gues u are using the 6 edged one? if u are just dont do it, u will ruin the heads on the bolts.
post Jul 10, 2014 - 2:56 PM
msk59
Joined May 10, '14
From Tulsa, OK
Thanks. I have not opened the engine yet. I have both types of sockets but I saw on ToyotaNation a picture of a different (thinner in diameter) style used.
I am in the planning stage:
- making a list of parts/supplies I would need (spreadsheet)
- What I need to get from stealership and which one from RockAuto
- establishing a budget and
- Schedule.
I am Project Manager by trade so this is a project for me (LOL)
post Jul 10, 2014 - 2:58 PM
Tort1llaboy
Joined Nov 25, '13
From Norway
are u rebuilding the engine or just the head?
post Jul 10, 2014 - 3:05 PM
msk59
Joined May 10, '14
From Tulsa, OK
I will take the head off and get it checked by a machiine shop to see if any of the seals etc need to be replaced. In the meantime I will pull pistons out, clean them and install new rings. Hone the cylinders. I figured if I have gone this far, might as well take care of any potential future issues if spotted earlier.
post Jul 10, 2014 - 3:11 PM
Tort1llaboy
Joined Nov 25, '13
From Norway
smart move... u might aswell change all the bearings. but when u clean the head i found that pant thiner was the best thing to clean the exhaust ports whit biggrin.gif worked like a BOSS biggrin.gif
post Jul 10, 2014 - 3:12 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (Tort1llaboy @ Jul 10, 2014 - 11:55 AM) *
I tryed the piston soak and it dint work... so now i have started rebuilding a new engine tongue.gif I allready got most of the parts so dint se the reason why i shuldnt tongue.gif
Almost done whit the head, just some fine polish on the valves and im done biggrin.gif
Provided it's in the valve-train anyway, which hopefully it is. If not will have to remove the engine and redo the cylinder walls and pistons.
2001 Miata LS 5-speed
post Jul 10, 2014 - 4:56 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
The head will get cleaned when you have it resurfaced. You need standard twelve point sockets for the head bolts. Normally 6 point sockets are recommended for hex bolts because they are less likely to round a bolt head off, but I believe a 12 point bolt head and matching socket have more surface area in contact so this is likely why toyota picked it.
You should check the clearances of the cylinder bores before you put new rings in, they will tend to become out of round in the directions the crank rotates and can develop a taper(wider at the top or bottom) from the force of the piston rod. Take measurements on the top, center and bottom of the cylinder both parallel and perpendicular with the length of the engine, if your unsure then take the block to the shop and have them check and or hone the bores.
I second checking and replacing worn rod/main bearings. Couple $s worth of plastigauge since you already have the lower end apart, money well spent. Make sure the machine shop shims the valves properly, if you provide them with the camshafts and cam bearing caps they can do this for you.
You WILL need a head gasket.
You SHOULD get-
head bolts ($20, they are torque to yeild which means they stretch and are not intended for reuse)
Full gasket set or head gasket set. It will contain all the gaskets for the engine except perhaps fuel injector orings
You COULD get-
Timing belt, its a non interference engine so you can drive it till it snaps without damaging the motor.
Water pump, while you have the motor apart its easy to replace
Oil pump, shouldnt wear but the tolerances can get out of spec, you want to oil your new motor properly right?
Im sure Im forgetting a lot but there is some info to munch on...
This post has been edited by Special_Edy: Jul 10, 2014 - 5:05 PM
post Jul 10, 2014 - 5:35 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Jul 10, 2014 - 7:30 PM
Special_Edy
Joined Oct 29, '11
QUOTE (Box @ Jul 10, 2014 - 6:35 PM) *
Yeah if you have to go to oversized pistons anyways, but is there any larger crank without grinding down the rod journals?
post Jul 10, 2014 - 8:08 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
Actually Smoking is not such a bad thing after all.
here is a public service announcement from Big Brother.
https://www.youtube.com/watch?v=IvLg4NuqZ-A
Bust a Deal; Face the Wheel.
post Jul 10, 2014 - 8:20 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (Special_Edy @ Jul 10, 2014 - 7:30 PM) *
It was more of a tongue in cheek remark since I really don't foresee it being worth all the trouble when you'd be better off dropping in a 20 valve if you want performance from the A family of engines.
post Jul 10, 2014 - 10:11 PM
msk59
Joined May 10, '14
From Tulsa, OK
Thank You all for wonderful help and tips. This is what i lack as an experience. I have what Special_Edy mentioned. I have checked the prices of OEM from an On-line dealer and Rock Auto. I will try to go through every thing and whatever is needed will be replaced.
I have a brand new set of sockets that will be used on this operation.
QUOTE (VavAlephVav @ Jul 10, 2014 - 8:08 PM) *
LOL. That is funny.
post Jul 11, 2014 - 1:44 AM
Tort1llaboy
Joined Nov 25, '13
From Norway
But abote the head bolts, i have spokent to a Toyota head mechanic and he sayd that u don need to change the head bolts, unless they are damaged or streched, there is a limit on how far they can strech.
so i will not change my head bolts. But if thay look good and no damage, just go ahead and use them again smile.gif
But Edy, or box. Do i have to use oversized rings after a hone?
post Jul 11, 2014 - 12:44 PM
Box
Joined Feb 23, '12
From Warrior, AL
I always use new head bolts, you're already spending a good sum of money as it is why skimp out now?
Depends on how much has to be honed out, is it only needing resurfaced and cross-hatched or is it needing to be brought back into round? Whoever is doing the machining should be able to tell you how far over they had to go.
post Jul 11, 2014 - 1:04 PM
Tort1llaboy
Joined Nov 25, '13
From Norway
QUOTE (Box @ Jul 11, 2014 - 12:44 PM) *
the head bolts are super expensive.. around 150 usd for me here in norway
post Jul 11, 2014 - 1:20 PM
Tort1llaboy
Joined Nov 25, '13
From Norway
i havent looked that good at the cylinders.
Btw whats the diference betwen the two valve seals? i got 2 diferent ones in my rebuild kit? one is kinda gold looking and the other one is just gray:P i have figured that its one type for the intake and one for the exhaust... but whish go where? tongue.gif
post Jul 11, 2014 - 3:16 PM
Box
Joined Feb 23, '12
From Warrior, AL
Try finding a hardware store that has a large selection of bolts, same thread and length in grade 8 is all you need.
They should be labeled in the kit, if not compare to the head.
post Jul 11, 2014 - 3:26 PM
Tort1llaboy
Joined Nov 25, '13
From Norway
QUOTE (Box @ Jul 11, 2014 - 4:16 PM) *
i might do that. smile.gif hmm the head i bought dint have any seals. so this might be tricky tongue.gif
post Jul 11, 2014 - 5:17 PM
Box
Joined Feb 23, '12
From Warrior, AL
Try looking around the internet for information. Whoever you got the kit from, see if they sell the intake and exhaust seals separately and have pictures for comparison.
Lo-Fi Version Time is now: November 23rd, 2024 - 3:09 PM
