7 Pages V  « < 3 4 5 6 7 >
> Help!! Smoking like its no tomorrow!, I need help to figure out what it is and how to fix it..
post Jul 16, 2014 - 2:49 PM
Tort1llaboy
Joined Nov 25, '13
From Norway
yeah that what we found out. Molycoat its called that we got. but non of the mechanics that worked at the local boat "garage" have used or heard abote that.
so we dint use it on the cumings diesel.
But in my case. I will asemble the engine so as parts arive so i think this engine will be done soon smile.gif
post Jul 16, 2014 - 2:56 PM
Box
Joined Feb 23, '12
From Warrior, AL
I've always used it. Besides you change the oil and filter again within a few hundred miles anyhow.
Yay working engines.
2001 Miata LS 5-speed
post Jul 16, 2014 - 3:41 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
On top of that a capful of oil in each cylinder and bump the engine over for ~20 seconds with the ignitor or coil unplugged, that way the oil system is primed before you actually fire it up.
post Jul 16, 2014 - 3:52 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Jul 16, 2014 - 4:54 PM
Tort1llaboy
Joined Nov 25, '13
From Norway
This post has been edited by Tort1llaboy: Jul 16, 2014 - 4:54 PM
post Jul 24, 2014 - 5:13 PM
Tort1llaboy
Joined Nov 25, '13
From Norway
Head is complealy done and the main rod and pistons are in. so tomorrow the head goes on the block biggrin.gif
post Jul 24, 2014 - 8:20 PM
Box
Joined Feb 23, '12
From Warrior, AL
Wooo, cleanliness.
post Jul 24, 2014 - 9:16 PM
msk59
Joined May 10, '14
From Tulsa, OK
What chemicals did you use to clean the pistons?
post Jul 25, 2014 - 5:47 AM
Tort1llaboy
Joined Nov 25, '13
From Norway
QUOTE (msk59 @ Jul 24, 2014 - 10:16 PM) *
i put the pistons in diesel for 24 houers. an then i just scraped the ring grooves whin an old ring thar i broke in to two, and used the "open" end of the ring.
post Jul 25, 2014 - 1:02 PM
Box
Joined Feb 23, '12
From Warrior, AL
Kerosene is another good cleaner.
post Jul 25, 2014 - 11:22 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
It would not hurt at all to add a couple extra oil return holes to the ring groove.
post Jul 26, 2014 - 10:15 AM
Tort1llaboy
Joined Nov 25, '13
From Norway
QUOTE (Bitter @ Jul 26, 2014 - 12:22 AM) *
post Jul 29, 2014 - 12:11 AM
msk59
Joined May 10, '14
From Tulsa, OK
What size socket to use on the head bolts 12 mm or 14 mm? . I got my engine apart. So far intake and exhaust are out and cams are out.
post Jul 29, 2014 - 9:24 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
I think the head bolts themselves are Star tool sockets
Bust a Deal; Face the Wheel.
post Jul 29, 2014 - 12:58 PM
msk59
Joined May 10, '14
From Tulsa, OK
I had a call in to my local Toyota dealer and they called me back to say that I can use 10mm, 12 point socket
post Jul 29, 2014 - 3:20 PM
Special_Edy
Joined Oct 29, '11
Normally a 12 point socket allows twice as many angles to fit the socket over the bolt head, but has less surface area to grab a 6 point head, so it will often round off a highly torqued 6 point bolt.
Toyota decided on a 12 point bolt because it has significantly more surface area than a 6 point bolt head
But I believe its a 12 point 12mm socket. The cam journal bolts are 10mm (6 point)
post Jul 30, 2014 - 6:49 AM
Tort1llaboy
Joined Nov 25, '13
From Norway
QUOTE (msk59 @ Jul 29, 2014 - 12:58 PM) *
10 MM 12 point
QUOTE (Special_Edy @ Jul 29, 2014 - 3:20 PM) *
post Jul 30, 2014 - 8:01 AM
msk59
Joined May 10, '14
From Tulsa, OK
Well: Pulled the head last night and no problems. i had a long 10mm 12 point socket. The exhaust side were torqued high it seems because they are longer than the intake.
The oil pan took the rest of the night. Those elan bolts were a pain, especially the one next to the ac compressor. End up taking the AC compressor and its bracket out to get to it. I will be replacing those bolts and they are not cheap from Toyota dealer.
Head will be taken to a machine shop to have them go over.
Pistons will be pulled tonight. In order to remember which piston goes where, I used a small punch ( a spring loaded punch from Harbor Frieght) and marked dots 1 to 4 on each piston surface. The cylinder walls looked good and the ridge on the top was non-existant. Some cross-hatched were noticed.
Sorry to highjacked your thread again. I will start a new when I download the pictures from my camera.
post Jul 30, 2014 - 9:39 AM
Tort1llaboy
Joined Nov 25, '13
From Norway
QUOTE (msk59 @ Jul 30, 2014 - 8:01 AM) *
post Jul 30, 2014 - 12:16 PM
msk59
Joined May 10, '14
From Tulsa, OK
Yes, this car came with AC, power steering but no cruise and fogs. I got the factory fogs installed but do not have all the parts for the CC yet. Have the actuator and cable but would need the CC-ECU and some wirings.
Lo-Fi Version Time is now: November 23rd, 2024 - 2:47 PM
