changing lights on dash, can i change the stock green to blue |
Feb 6, 2004 - 10:02 PM |
Enthusiast Joined Feb 4, '04 From Tampa Currently Offline Reputation: 0 (0%) |
I am wondering if I can change th stock lights in the dash behing AC and heater contorls from the green to another colour like blue or red? Is it a simple swicth of the bulbs?? If so does anyone know the number bulbs installed??
Feb 6, 2004 - 11:04 PM |
Enthusiast Joined Dec 11, '02 From Sioux Falls, SD, USA Currently Offline Reputation: 0 (0%) |
They're tiny LEDs, and require soldiering...it's not simple, and best left to someone that knows a lot about doing it. Someone around here was doing it for a fee a while back.
Feb 7, 2004 - 4:21 PM |
Enthusiast Joined Jul 8, '03 From Dallas, TX Currently Offline Reputation: 0 (0%) |
yes, it is doable, i changed them last week..
Feb 8, 2004 - 4:02 PM |
Enthusiast Joined Dec 24, '02 From Wirral, UK Currently Offline Reputation: 0 (0%) |
details please ? is yours a climate control setup.. mines a manual setup to change temp. I thought there were 2 tyep 194 bulbs inside the unit and then each button has it's own LED ? |
Feb 8, 2004 - 9:22 PM |
Enthusiast Joined Jun 24, '03 From MD Currently Offline Reputation: 0 (0%) |
Do a search, there was a post a few months ago that had a picture of the climate control with the face removed. It had some usefull information.
Feb 9, 2004 - 10:53 AM |
there are 3 bulbs and one LED for each button....
Its not too hard to replace them, just need to find the right bulbs...there was a post a few months earlier, should give you all the details....mine is a manual control... |
Feb 28, 2004 - 5:22 PM |
I was tinkering with my heater control cluster today.. it was a bit of a twat to get out - mainly the manual contrl cables.. but I did get access to the 3 bulbs in it.. AND may have found replacements !!
Having got the unit apart i went onto t'internet to find replacements and found these >>> http://www.superbrightleds.com/1157.htm type 74 bulbs on a base.. Instrument Cluster and Gauge Backlights Twist-Lock type instrument LED bulbs consist of a T 1 1/2 (#73/74) miniature LED bulb plugged into a twist-lock socket base. LEDS have wide viewing angle. Available with White Blue Green Red and Amber LED Overall length: 21mm Extends into cluster: 14mm needless to say along with a few other bits of Autoillumination.com (I bought from there before i found this site) I have got $50 worth of bulbs being sent o min ein the UK as there's f'all like these available in the uk ! |
Feb 29, 2004 - 7:50 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Could someone post a how to article on this. I would like to know how to do it, I wanna change the color of the led's in my climate control. So it matches my radio and indiglo gauges.
Mar 1, 2004 - 3:03 AM |
changing the actual LED's may be a bugger to do - I spoke to my uncle who designs electronic cicuitry and the like, his advice was that for the time and potential hassle of changing the LED, a better option was to use some stage lighting gel over the LED window to change the colour.
Someone has posted a thread on the work they had to do to change the LED's already but getting the right ones and the resistors was taking time and you had to order a large amount when you only needed a handful of components. |
Mar 1, 2004 - 3:54 AM |
I found a thread where someone changed all their led's to red. Here it is, got the led's and resistors from radio shack.
http://www.6gc.net/forums/index.php?showto...climate+control |
Lo-Fi Version | Time is now: November 30th, 2024 - 10:29 AM |
