intercooler questions?, Where is the best location |
Jul 15, 2014 - 11:27 PM |
Enthusiast Joined Aug 2, '06 From bay area Currently Offline Reputation: 21 (100%) |
I am getting ready to do a 2nd Gen 3sgte swap. Need intercooler and not sure which route is the best way. I have a preface with preface fogs, I was looking at the front end today. I don't think I have enough room for piping with the fogs? For the people who have a front Mount, can u guys post some pics of the piping and specs of the intercooler please.
Jul 16, 2014 - 3:45 PM |
Enthusiast Joined Aug 2, '11 From southampton Currently Offline Reputation: 0 (0%) |
I used 2.25" pipes, and kept the fogs (post face lift though). Drivers side just goes under front and up behind the radiator, passenger side goes through where the air box was, under the fuse box and into engine bay. Will try to find pictures from my build.
Did not need to remove anything, including air con. edit - not sure if I am allowed to post this, sorry mods if not and please delete. Link to my 3sfte build thread, shows some of the intercooler route http://www.celica-club.co.uk/forum/index.p...n-thread/page-4 This post has been edited by digs: Jul 16, 2014 - 3:48 PM |
Jul 17, 2014 - 7:22 AM |
intercoolers are just that, get one that fits! measure the space between the fogs and find one online that works.
Jul 17, 2014 - 9:31 AM |
Jul 17, 2014 - 10:22 AM |
Water cooled is a pretty good option if you don't mind the extra weight.
I might also suggest the side mount intercooler as another option. Audi does dual side mounts from the factory, VW 1.8T uses a single side mount. |
Aug 7, 2014 - 4:09 AM |
Enthusiast Joined Aug 11, '08 From London Currently Offline Reputation: 7 (100%) |
Aug 7, 2014 - 7:44 AM |
FMIC is the best for a "set it and forget it" kind of thing.
You can play with the piping. You don't need 3" piping until you start getting to well over 600hp, and 2.5" piping isn't necessary either. 2" piping is good for up to 400hp worth of air flow, which is when it becomes a restriction. I have a 2" hot side(pre-intercooler) and 2.5" cold side (post-intercooler), mainly because the turbo outlet is 2". -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Aug 7, 2014 - 11:28 AM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
-------------------- st205 powered ss3 coupe
Aug 9, 2014 - 1:15 AM |
why does it escape so many that you can clock the turbo down so you dont have to run all that piping up and over the engine.
Aug 9, 2014 - 8:04 AM |
why does it escape so many that you can clock the turbo down so you dont have to run all that piping up and over the engine. I would like to revise the setup and clock the turbo at some point. Only thing that needs to be done is a custom bracket has to be made to clock the turbo (which I know you know Jeff) Azn87 you can easily make a FMIC setup work with the preface fogs. Space is tight but it can be done and could probably be done differently than what mine is as well. -------------------- st205 powered ss3 coupe
Aug 11, 2014 - 8:23 AM |
Enthusiast Joined Dec 4, '11 From Greece Currently Offline Reputation: 1 (100%) |
Aug 12, 2014 - 10:00 PM |
thanx for all the support!!
Lo-Fi Version | Time is now: November 22nd, 2024 - 12:49 PM |
