> beefing up the beams
post Jul 31, 2014 - 7:45 PM
Rooster92
Joined May 8, '14
From Houston
Hey all im wondering what all i would need to build up my 3sge beams motor so i cab drop the compression and run a low (6/10) boost. Any info is appreciated. From what i understand i can put a thicker head gasket on it and drop the compression a little, get a custom turbo manifold and then go from there and run 6psi and be fine. But i want a little more power so.. any options?
Thanks
-chris
post Jul 31, 2014 - 9:38 PM
Rooster92
Joined May 8, '14
From Houston
QUOTE (Rooster92 @ Jul 31, 2014 - 8:45 PM) *
Thanks
-chris
Also isnt the block the same as the 3sgte blocks or no?
post Aug 1, 2014 - 12:03 AM
enderswift
Joined Jul 12, '08
Blocks are very close but not exactly the same. Small differences exist. The only way you can drop compression enough to run a turbo would be to use low compression pistons. Thing is, lowering the compression on the beams kinds defeats the purpose of the engine. Plus you would be hard pressed to find a way to keep vvti functional while being able to tune for a turbo.
post Aug 1, 2014 - 1:53 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
you dont need to lower compression. we have been boosting 2ZZ engine for YEARS!!! if you want to boost your engine, please do the research. you have a lot to learn
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 1, 2014 - 6:51 AM
Rooster92
Joined May 8, '14
From Houston
QUOTE (Smaay @ Aug 1, 2014 - 1:53 AM) *
I know i can boost the engine, but not much, VVTI shouldnt be to big an issue, when the 2jz got VVTI it still was turboed and kicked ass.
Lo-Fi Version Time is now: December 2nd, 2024 - 4:08 AM
