car choking. help!! |
Aug 7, 2014 - 9:10 PM |
Enthusiast Joined Nov 29, '07 From california, marysville Currently Offline Reputation: 0 (0%) |
My car started choking out of nowhere at first it wasn't too bad but it gets worst as I kept driving it. The cel turns on whenever it chokes (flashes as the car chokes then goes off as the car drives normal again). So one day I decided to plug in my code reader and drive with it to see if I can catch any codes but the car drives perfect with the code reader plugged in. And recently my headlights just died.. but high beams work so I switched the two and my low beams r back on . Idk if they are related to one problem. Any suggestions? I already changed spark plug, spark plug wires, cap and rotor. Thanks
Aug 8, 2014 - 12:05 AM |
Enthusiast Joined Nov 4, '09 From Sacramento, California Currently Offline Reputation: 0 (0%) |
this is going to sound odd... is the battery ok?
-------------------- Brand new 6gc owner! (sort of 2011)
The world is moving around a sun, the sun moves around a local arm of the galaxy, the local arm of the galaxy moves around a gigantic black hole. |
Aug 8, 2014 - 3:44 AM |
Aug 8, 2014 - 11:21 AM |
Enthusiast Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
if you got a CEL the code that caused it should be stored in the memory, unless the battery was disconnected since then. did you try jumping Te1 and E1 to count the flashes?
-------------------- Bust a Deal; Face the Wheel.
Aug 10, 2014 - 3:32 PM |
I'm got getting anything from those terminals and my code reader isn't giving me anything from the history
Lo-Fi Version | Time is now: December 12th, 2024 - 11:39 AM |
