12 Pages V  « < 5 6 7 8 9 > »
> Finally brought my Supra home!, '97 TT 6 speed
post May 24, 2016 - 9:10 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
You don't like wet noodles?
post May 24, 2016 - 9:57 PM
Box
Joined Feb 23, '12
From Warrior, AL
Wet noodles aren't good for anyone.
2001 Miata LS 5-speed
post Jun 15, 2016 - 10:59 AM
richee3
Joined Jun 29, '08
From Denver
Currently Online
Finally got a chance to get my car up on the dyno last weekend. Made 460 whp, 465 wtq at 20 psi. Strong numbers for stock twins, especially given 75% humidity.
First run was 456 whp, second run was 462 but the printout says 460. No use crying over 2 hp.
https://youtu.be/BGfEfS62zT8
https://youtu.be/Jv-8JL57jrs
https://youtu.be/9slGRGULkHg
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 15, 2016 - 12:27 PM
Jmk91
Joined Jan 25, '15
From United States
That car is very beautiful. It's everything the celica isnt. If the celica was factory rwd I wouldn't know what one to choose! I've never been in a 400whp+ car (270ish Hondas is the fastest for me) I bet it slams you back in your seat. If your ever in ohio I'll give ya 20$ for a ride and a photo hahaha.
This post has been edited by Jmk91: Jun 15, 2016 - 12:28 PM
post Jun 15, 2016 - 2:02 PM
Box
Joined Feb 23, '12
From Warrior, AL
Those do seem like really good numbers for a mostly stock setup, but what's with the Alabama level of humidity though? tongue.gif Even my comparably mild Firebird will throw you back, so I'm sure his Supra definitely does. Start taping an $100 to the edge of the dash and see if people can grab it before you leave second gear. laugh.gif
post Jun 15, 2016 - 7:50 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
Forgot to specify earlier, this isn't my daily setup. This was with half a tank of 93 octane and half 110 so I can run full advanced timing. Apparently the 2JZ runs pretty advanced timing and pulls timing back pretty hard on pump gas. Along with that, I'm able to turn the boost up past my daily setup. I daily the car under 18 psi, but I've seen people turn it up as high as 23 psi with pump gas. I stayed conservative and only turned up to 20. That's past the turbos' efficiency range and makes good torque but not much more power, not to mention they can only handle so much abuse. Another thing to note is that the dyno isn't a true representation of my power curve, only peak power.
JMK, if the Celica had a RWD option, it would be my choice hands down. The Supra is a great car but the Celica is lighter and easier to chuck around a corner. My Supra won't throw you back in your seat though. The sequential twins bring on the power very smoothly, so much so that I was stunned when it dyno'd at 460 whp. That's exactly where it SHOULD dyno at, given my current setup, but I still didn't expect it to actually be that high. It hauls ass but it's never violent.
Box, we always have high humidity up here. Today was 90%, nothing out if the ordinary. If I taped a $100 bill to my dash, I'd lose $100. I don't make the same power in the lower gears that I do in the higher gears. Since there's not as much load on the engine, the turbos just don't spoil the same way as they do in the higher gears. The car isn't slow to 60 but it's definitely not fast either. It pulls harder in 4th than it does in 2nd. So basically, I've got no way to keep my $100 on the dash.
At this point, I'm due for upgraded intercooling. The stock side mount is still efficient.... assuming all the fins were still intact. Plus it'll be nice to get some hard pipes to replace the stock soft pipes. Still need to focus on suspension before even thinking of more power.
1998 Celica GT-
BEAMS Swapped.
post Jun 15, 2016 - 8:14 PM
Box
Joined Feb 23, '12
From Warrior, AL
Ahh, so it was a number bragging run. Yeah humidity sucks, even on an otherwise cool day humidity can make it miserable. I guess it's a matter of power delivery, in that case make it for 4th gear pulls only. tongue.gif
post Jun 15, 2016 - 8:57 PM
cheela
Joined Feb 2, '07
From Berlin, WI
Stop being so modest. You're a supra owner. We all know they're jackasses. laugh.gif
post Jun 15, 2016 - 9:07 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
What kind of boost controller are you running? I just got off the dyno yesterday with the four. Numbers were pretty dismal (231whp & 264wtq) My boost controller was faulty though, not staying calibrated and wouldn't hold boost. If my luck runs well, I will be back on the dyno this weekend with a HKS evc 5 instead of the faulty GFB2 EBC.
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Jun 15, 2016 - 9:12 PM
Bitter
Joined Mar 11, '06
With great power comes great responsibility - said no Mustang owner ever
Jmk91
Joined Jan 25, '15
From United States
I'm shocked it doesn't throw you back into your seat. 4th gear pulls are where it's at. Interstate speed races... pull up next to you and rev the engine haha.
post Jun 15, 2016 - 9:41 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
QUOTE (Box @ Jun 15, 2016 - 8:14 PM) *
Pretty much. I was going to dyno it at my daily numbers, but.... It was a dyno shootout. Everybody else was turning everything up, so I was obligated. Plus "f*** you" numbers are always nice to have. I'm planning on doing another dyno run later to get my daily numbers when we aren't on limited time. That way I can get my AFR's, true daily driven figures, and an accurate power curve. The one on my chart shows no boost until after 4K, as the guy in the car held the throttle steady and floored it about when both turbos come online. So basically my graph is accurate after a certain point but a better test would have been to hold steady at like 1,500-2,000 rpm and floor it from there.
QUOTE (cheela @ Jun 15, 2016 - 8:57 PM) *
QUOTE (4-eyed-freek @ Jun 15, 2016 - 9:07 PM) *
I'm running twin NXS MBC's, a standard NXS on my EBV to control the first turbo and an NXS Signature series on the wastegate. No real complaints about either one, but they're both just standard manual boost controllers with no frills. Your EBC should give better response than my MBC's. What kind of dyno were you on? Temp/humidity? Those numbers are nothing to sneeze at, even if they weren't what you were expecting!
QUOTE (Bitter @ Jun 15, 2016 - 9:12 PM) *
Good thing Zach moved to Florida and switched to motorcycles! He dodged a bullet!
QUOTE (Jmk91 @ Jun 15, 2016 - 9:12 PM) *
It puts you back in the seat, but it doesn't throw you back, if that makes any sense. It's such a smooth power curve that it doesn't keep you pressed into the seat. It does, however, like to squat pretty damn hard on the rear suspension and need a grippier tire. As Supra owners, we know that digs aren't our forte, hence all the highway roll videos!
1998 Celica GT-
BEAMS Swapped.
post Jun 15, 2016 - 11:47 PM
Bitter
Joined Mar 11, '06
How fast does a 1000hp Supra run the 1/4 mile? 12 seconds.
How fast does a 500hp Supra run the 1/4 mile? 12 seconds.
post Jun 16, 2016 - 12:28 AM
Box
Joined Feb 23, '12
From Warrior, AL
Uncle Ben was actually killed by a Mustang doing a burnout as it left a car show.
1/4 mile isn't everything you know, also said no Mustang owner ever.
This post has been edited by Box: Jun 16, 2016 - 12:29 AM
post Jun 16, 2016 - 7:01 AM
4-eyed-freek
Joined Apr 17, '10
I wouldn't say im very upset, but I wasn't all that enthused. It was a dyno-jet and pretty warm for my area @ 80deg & roughly 30% humidity. The controller performed so poorly that I made peak power and tq at 3,500rpm. After that the boost fell 5-9 psi and wouldn't hold. I am convinced the meth helped though seeing as every run got better and better as it got warmer and warmer outside. soooo I think you supra needs to become a drug user laugh.gif
This post has been edited by 4-eyed-freek: Jun 16, 2016 - 7:01 AM
post Jun 16, 2016 - 9:40 AM
richee3
Joined Jun 29, '08
From Denver
Currently Online
QUOTE (4-eyed-freek @ Jun 16, 2016 - 7:01 AM) *
Strange, Dynojets normally read higher than Mustang dynos. Your numbers wouldn't be too far off of Mustang numbers since they're always 12% lower. However, if you aren't holding boost then it's not a dyno issue at all. The temperature wasn't doing you any favors but it could be worse. I want to know what you'll make with the new EBC! Supra guys aren't big on meth injection for some reason. I haven't looked that far into it. They all prefer E85 or race gas over meth injection, although I can say from personal experience that race gas is a little more painful on the wallet.
1998 Celica GT-
BEAMS Swapped.
post Jun 16, 2016 - 9:50 AM
Jmk91
Joined Jan 25, '15
From United States
QUOTE (Bitter @ Jun 15, 2016 - 11:47 PM) *
http://m.youtube.com/watch?v=914hzQeTnw0
Worlds quickest supra
Under 6 seconds.
This post has been edited by Jmk91: Jun 16, 2016 - 9:54 AM
post Jun 16, 2016 - 3:11 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
You're welcome.
In sequential set-up, the power is a lot more linear minus that odd dip when the turbos transition from turbo 1 to turbo 2, so you won't feel that sudden UMPH when boost kicks in like you would with a single turbo set-up. It'll just slip into your DMs. Also have to consider that the Supra is a pretty hefty car at about 3600#. Like Daniel said, the power will press you into the seat, but it won't throw you into it.
Setting the turbos into true twin should give it more of that kick that you're expecting, but it won't be enough to bring home to mama. My twins are currently set-up as permanent true twin, so I can't really comment the difference as that's how I arranged my turbos when I initially started my swap.
-Alex {](O_o)[}
post Jun 16, 2016 - 3:16 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Can't get traction for sh!t! lol
QUOTE (Jmk91 @ Jun 16, 2016 - 9:50 AM) *
Under 6 seconds.
Tubbed.
-Alex {](O_o)[}
post Jun 16, 2016 - 3:28 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
No "meh?"
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: December 1st, 2024 - 10:07 PM
