12 Pages V  « < 6 7 8 9 10 > »
> Finally brought my Supra home!, '97 TT 6 speed
post Jun 16, 2016 - 7:15 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
QUOTE (Box @ Jun 15, 2016 - 2:02 PM) *
Those do seem like really good numbers for a mostly stock setup, but what's with the Alabama level of humidity though? tongue.gif Even my comparably mild Firebird will throw you back, so I'm sure his Supra definitely does. Start taping an $100 to the edge of the dash and see if people can grab it before you leave second gear. laugh.gif
I know you're talking about this,
but he's got 1200hp, five 100 dollar bills, and a whole lott'a silicone.
https://www.youtube.com/watch?v=yW02gO0E1_Y
This one is called Supra vs World.
It has many exapmples of how the boost kicks in on the highway against most every car you can think of and even a couple of bikes.
https://www.youtube.com/watch?v=pDBcR-XKIi8
This post has been edited by VavAlephVav: Jun 16, 2016 - 8:19 PM
Bust a Deal; Face the Wheel.
post Jun 16, 2016 - 11:00 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
QUOTE (richee3 @ Jun 16, 2016 - 3:28 PM) *
No "meh?"
it's implied.
-Alex {](O_o)[}
post Oct 17, 2016 - 9:28 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
Not so much of an update as it is just me keeping track of the small things. Finally drained and refilled the rear diff and trans. Easy job, not expensive, but I don't think it has ever been done. The gear oil had quite a bit of metal shavings in it. Not an abnormal amount, but the car is 19 years and 91,000 miles old. Definitely should have been flushed by now. Trans fluid was free of metal shavings but still pretty old. While I was under there I decided it would be a good idea to change my trans mount. It's too easy to simply ignore, even if the old one wasn't completely worn out yet.
That's all for now. After this weekend I'm turning the boost down and focusing on freshening up the car. Again, nothing to update, just keeping track of the little things.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 17, 2016 - 10:24 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (richee3 @ Oct 17, 2016 - 9:28 PM) *
Finally drained and refilled the rear diff and trans. Easy job,not expensive, but I don't think it has ever been done.
It is if you use this as recommended: https://www.amazon.com/Toyota-Genuine-Fluid...e/dp/B004SL86M6 That $100 fill, mmm...
2001 Miata LS 5-speed
post Oct 17, 2016 - 10:31 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
It's glorified ATF. Yet, some people still swear it's literally the only choice to fill the V160 with, despite all the evidence that it's just ATF, nothing more. One guy even sent several samples off for analysis and found that Castrol Transmax for imports as well as Toyota T-IV ATF are virtually identical and perfectly suitable replacements for V160 juice.
1998 Celica GT-
BEAMS Swapped.
post Oct 17, 2016 - 10:36 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (richee3 @ Oct 17, 2016 - 10:31 PM) *
It's glorified ATF.
Just like GM's MTF for the T-56, but at least it's only $6 a quart.
post Oct 17, 2016 - 11:09 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Should've gone with the TRD mount. don't recall if it's discontinued doe....
My tranny is 80% V160 jizz and 20% synthetic ATF. so far, no problems.
Do another change of your rear diff fluid in a few thousand miles to flush out the rest of the metal shavings. Rear TT diff ain't cheap. lol
-Alex {](O_o)[}
post Jul 17, 2017 - 12:30 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
Finally got rid of my aging side mount intercooler and got a FMIC.
That's all, not much of an update.
1998 Celica GT-
BEAMS Swapped.
post Jul 17, 2017 - 7:20 PM
Box
Joined Feb 23, '12
From Warrior, AL
Hey look you left the crash bar intact!
post Jul 17, 2017 - 8:13 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
"I don't understand why it's overheating"
post Jul 17, 2017 - 8:15 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
Looks mighty fine!
JDM Part King
post Jul 18, 2017 - 8:54 AM
richee3
Joined Jun 29, '08
From Denver
Currently Online
QUOTE (Box @ Jul 17, 2017 - 6:20 PM) *
Safety first! I wouldn't do it any other way. If a mod compromises the car, it's just not worth it in my opinion.
QUOTE (Bitter @ Jul 17, 2017 - 7:13 PM) *
A lot of intercoolers for the Supra do have this issue but the HKS Type S is relatively small as far as Supra FMIC's go, and allegedly doesn't contribute to any overheating issues. However it's pretty hot up here so real world results are still TBD.
QUOTE (1994Celica @ Jul 17, 2017 - 7:15 PM) *
Looks mighty fine!
Thanks! It's gotta be, like, 1,000 hp now. Maybe even 1,100. But realistically I didn't do this as an upgrade or to squeeze every last hp out of the car. I'm just trying to combat increased IAT's and replace a pretty beat up stock side mount.
1998 Celica GT-
BEAMS Swapped.
post Jul 18, 2017 - 9:45 PM
Bitter
Joined Mar 11, '06
If it runs a little warm just come back down to where the air is thicker. smile.gif
post Jul 19, 2017 - 8:03 AM
cheela
Joined Feb 2, '07
From Berlin, WI
Subarus run better on Colorado air. you should trade it in.
post Jul 19, 2017 - 12:50 PM
Bitter
Joined Mar 11, '06
He's not a lesbian.
post Jul 19, 2017 - 1:00 PM
cheela
Joined Feb 2, '07
From Berlin, WI
did you just assume his/her's gender?
post Jul 19, 2017 - 6:27 PM
Box
Joined Feb 23, '12
From Warrior, AL
He/she could also be a lesbian trapped in a man's body, let's not assume their gender identity or sexual orientation either.
This post has been edited by Box: Jul 19, 2017 - 6:28 PM
post Jul 19, 2017 - 7:00 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
I like cars. I'm not entirely sure what gender that makes me.
1998 Celica GT-
BEAMS Swapped.
post Jul 19, 2017 - 8:19 PM
Bitter
Joined Mar 11, '06
Well with hair like they have...
post Jul 19, 2017 - 8:30 PM
Box
Joined Feb 23, '12
From Warrior, AL
I think it makes you an automaton.
This post has been edited by Box: Jul 19, 2017 - 8:56 PM
Lo-Fi Version Time is now: December 1st, 2024 - 10:16 PM
