Enthusiast Joined Aug 3, '14 From cottage grove, mn Currently Offline Reputation: 0 (0%) ![]() |
I have an extra set of 16" 7gc rims that came with my car with no rubber. I did some calculations and 225/45r16 is very close in diameter to 205/55r15 as to not mess with my speedo readings. Is it possible for these tires to fit without hitting suspension/fenders/wheelwell? Anyone know how wide I can go? Anything helps. Thanks!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
finding a 225/45R16 tire is near impossible these days unless its a track tire.
a 225/50R16 will rub on the rear of the wheelwell. there's no reason i see to going wider than 225 really even though you can fit a 235 on there. 215 wide tires is optimal even for a 217hp Integra Type R from the factory. unless your putting out mad crazy hp and have a turbo. but even then you can do other suspension mods to put power to the ground -------------------- Group buy to replicate Narrow E series transaxle parts
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) ![]() |
Go 205/50/16 and call it good. Cheaper and looks better.
Can the 225s fit with spacers? I want to corner like a beast. Do you think the 205s will hold up well? Possibly go 205s with lower profile?
Enthusiast ![]() ![]() Joined Jan 20, '13 From Los Angeles Currently Offline Reputation: 5 (100%) ![]() |
On corners rated 25mph I've been able to go close to 60mph without losing traction with 205's (stock GT tire specs). Of course, I have Eibach lowering springs and ST sway bars. Been wanting to go with 225-235 spec tires with wheels but a lightweight set of wheels are hard to come by with our wheel pattern.
This post has been edited by 955SFE: Sep 16, 2014 - 1:03 PM -------------------- |
Enthusiast ![]() ![]() ![]() Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) ![]() |
thats a 16x6 1/2 i wouldnt go over 215/45 or 215/50
istick wirh 205 o. those, best performance |
Enthusiast ![]() ![]() Joined Aug 26, '11 From ventura, ca Currently Offline Reputation: 10 (100%) ![]() |
On corners rated 25mph I've been able to go close to 60mph without losing traction with 205's (stock GT tire specs). Of course, I have Eibach lowering springs and ST sway bars. Been wanting to go with 225-235 spec tires with wheels but a lightweight set of wheels are hard to come by with our wheel pattern. lightweight , quality and 5x100 is available just costs lots of $$$$ or the offset isnt ideal either alot of times. |
On corners rated 25mph I've been able to go close to 60mph without losing traction with 205's (stock GT tire specs). Of course, I have Eibach lowering springs and ST sway bars. Been wanting to go with 225-235 spec tires with wheels but a lightweight set of wheels are hard to come by with our wheel pattern. lightweight , quality and 5x100 is available just costs lots of $$$$ or the offset isnt ideal either alot of times. The struggle. Lol. Just convert and join the 5x114.3 club. Lol. -------------------- |
Lo-Fi Version | Time is now: February 18th, 2025 - 3:18 AM |
