14 Pages V   1 2 3 > »
> how to swap a 2grfe V6 into a st204, Toyota reliability, with less moving parts than a turbo
post Aug 12, 2014 - 4:24 AM
Will start an official thread, into this. wont go into detail. Will keep it mostly informative, because i know this will not be a favorite swap for most, and will be cost prohibitive for many.
Approximate cost of swap is around 7 to 8K, and will vary according of how far you want to go. mods and stuff
not going to get into detail about, a shopping list, or what not. there are multiple places you can get it, and it has been discussed before.
DSCN1196
the engine fits, and it barely makes it. will not fully disclose all that is being done, but will mos likely help anyone that wants to do this personally.
fitting the engine and mating the engine, can be found in the MR2OC forums, and i will not take credit for it.
Please lets not fill this thread with garbage. Its a 2grfe, because i wanted it, and if you dont like it, oh well, you are not paying for it, lol....
first things first, the engine needs to come from the bottom, it wont come from the top... it wont...
DSCN1202
DSCN1188
there are some body modifications, and will get into details later in the swap... I have my reasons.
the swap is doable. and like I said, im willing to help personally to any member, that will do it.
Will be a slow guide, because i decided to do it all myself, with no help. I feel like this is more personal....
Will include more stuff in the days to come...
DSCN1122
just consider the 2grfe, its worth it. all aluminum...
This post has been edited by njccmd2002: Sep 22, 2017 - 7:15 PM
post Aug 12, 2014 - 4:31 AM
It wont clear the regular hood, but it will clear a gt4 hood, with some modifications to be confirmed...
there is some tapping and drilling to be done to tranny, and engine.... (all is covered in MR2OC), and all credit goes to guoky...
DSCN1182
DSCN1186
and how the pros do it to mount their engines to the tranny. using headless bolts
DSCN1183
This post has been edited by njccmd2002: Sep 20, 2017 - 10:00 PM
post Aug 12, 2014 - 9:14 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
if I recall, the 2GR bolts right up to the E153 with no drilling or mods. use ST205 mounts and you have 3 right off the bat.
Im surprised you cant get the engine installed from the top, I can pull the 3S-GTE and AWD trans out the top with no problem. and the 3MZ went in with no problems either.
I cant wait to see your finished product, ill never go the 2GR route unless an engine falls in my lap for free. im really happy with the 3MZ.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 12, 2014 - 2:04 PM
The engine is easier to maneuver from bottom. Its bulky and it hits the frame several places. You have to disconnect a/c lines and ps lines. I have to cut the frame. And there is barely space for the regular rad fan. Its just to bulky. I dared not try and get it jammed.
I understand your point. Yes its expensive. And its not for everyone. By all means its not the best swap. But this is the last thing o do to my car and wanted to do something memorable. Lol, i still dont know if ill be able to clear the rack with the headers.
post Aug 13, 2014 - 8:10 AM
ok few more bits of information...
you just cant go straight to make the engine mount. you need to have a temporary mount to give you an idea of what needs to be cut and addressed.. in the engine bay. i suggest like i said earlier to remove the power steering an lines, and the a/c lines, unless you want to run the risk of damage...
DSCN1290
not yet sure if there is enough space for guoky headers in the rear, they fit for the front..
DSCN1293
Smaay, the upper bolt needs to be tapped.. its smooth. and you have to grind the engine in certain areas to mate the transmission..
front bracket area
DSCN1187
rear bracket area
DSCN1181
oh and forgot, fan relays are no go, move them
DSCN1189
This post has been edited by njccmd2002: Sep 20, 2017 - 10:16 PM
post Aug 13, 2014 - 8:14 AM
oh and if youre going to be grinding, protecto engino
DSCN1179
This post has been edited by njccmd2002: Sep 20, 2017 - 10:19 PM
post Aug 13, 2014 - 3:42 PM
richee3
Joined Jun 29, '08
From Denver
Berto, you cray cray! Good progress with the 2GR so far. Very brave for tacking this swap in a Celica with virtually no support.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 13, 2014 - 10:14 PM
Thanks, was hesitant to make a swap thread, but i said WTH...
anyways... here is why you shove this engine from the bottoms...
DSCN1296
this is the engine mounted, and on the temp mount...
but that is not a problem..
DSCN1302
obligatory swap picture...
DSCN1304
DSCN1305
and finished..
DSCN1306
i had to pull this engine 6 times up and down, up down to measure the cutting and notching the frame...
i had to notch for the head, and steering pump....
this is another angle from the crossmember.. you barely have clearance..
DSCN1294
and
DSCN1295
a stupid trick to line up the engine i learned...
DSCN1301
and once again, out, awaiting flywheel, and i will clean the transmission. its dirty...
DSCN1307
and while that is out, this may get refreshed..
DSCN1297
still lots to do, and so little time...
This post has been edited by njccmd2002: Sep 20, 2017 - 10:55 PM
post Aug 13, 2014 - 10:19 PM
Box
Joined Feb 23, '12
From Warrior, AL
Damn, that's a tight fit.
I can't wait to see it all buttoned up.
This post has been edited by Box: Aug 13, 2014 - 10:20 PM
2001 Miata LS 5-speed
post Aug 14, 2014 - 8:18 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Love this. Great work Berto!
~bloodMoney
post Aug 14, 2014 - 9:47 AM
enderswift
Joined Jul 12, '08
You are living our collective dream Berto. Awesome work
This post has been edited by enderswift: Aug 14, 2014 - 9:47 AM
post Aug 15, 2014 - 8:23 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
post Aug 19, 2014 - 5:15 PM
kevin311
Joined Dec 23, '12
From North Carolina
Glad you decided to make a thread. F*** the haters. The price tag on this deters me but I'm down for someone taking a crack at something new for the 6gc. I commend you though for doing this on your own. Can't wait to see and hear the end result. Nice work!
post Aug 19, 2014 - 6:29 PM
thanks, no updates for now, except got the aluminum flywheel, and suspension parts, totaling 800 this month. so i fugured will wait next month, for more parts, and work with what i have. No rush to do this yet.
post Aug 19, 2014 - 8:55 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
keep up the good work and the updates
post Aug 20, 2014 - 9:35 AM
this thread is already so full of win, most people who see it wont even grasp how goddamn cool this is.
i cannot wait to see this car in person in a couple weeks!
sure, cost is thru the roof.
sure, gotta have balls big enough to modify the chassis to suit.
sure, this is gonna be the fu^king coolest v6 swap on this site by about 8 billion miles!
DOOO ITTTTT berto!!!!!!
post Sep 16, 2014 - 10:36 PM
richee3
Joined Jun 29, '08
From Denver
Updates?
1998 Celica GT-
BEAMS Swapped.
post Sep 17, 2014 - 6:48 PM
FORGMANN
Joined Dec 11, '04
From USA
I know many of you are think man this would be sweet turbo'ed and in a ST205
Wonder if you can use 4WD gearbox ? Below is your answer posted in July
Anyone from Russia or eastern Europe have any more details on swap?
i could not find any anywhere .. Those crazy Russians tuners
Do not post here if you do start a new thread .
Avensis (same chassis family as st246 Caldina and 1ST gen TC)
https://www.youtube.com/watch?v=MkstuZACBQI
https://www.youtube.com/watch?v=lsQv-1zZq9w
Berto
Once you get running and then get power hungry again afterwards
i will have extra TRD S/C waiting as i now have 2 .. We all know 276 whp is never enough HP!!
Old guy with the toys
95 ST205 WRC (the real deal)
94 MR2 HARDTOP Supercharged 2GR/6SPD 22 owned
post Sep 17, 2014 - 8:26 PM
haha, yeah!. gonna have to chop some hood!!
ill put some work in it tomorrow and friday. this is really slow......
too many things in right now...
post Sep 17, 2014 - 8:30 PM
richee3
Joined Jun 29, '08
From Denver
It doesn't seem to me like there's a lot left. You pretty much have the mounting figured out, and that's a huge chunk of the work. After that you'll be able to send your wiring out, order and assemble your axles, mount everything up and plug it in, figure out radiator hoses, and turn the key. Any time you need a hand with this you've got my number! I work for free. smile.gif
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: April 21st, 2025 - 2:49 AM
