how to swap a 2grfe V6 into a st204, Toyota reliability, with less moving parts than a turbo |
Nov 13, 2014 - 10:52 PM |
braze over the welds to fix the leaks, it's like solder for steel.
Nov 13, 2014 - 11:23 PM |
braze over the welds to fix the leaks, it's like solder for steel. regular braze? silver solder for copper? i dont have oxy, i have a mapp, and dont know if i can braze metals... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 14, 2014 - 2:23 AM |
Mapp can get hot enough to braze, especially if it's light metal and you have one of those whistling turbo torches. Those things get HOT.
Nov 22, 2014 - 8:13 PM |
ok getting ready for surgery. Someone here sent me this box in
DSCN1474 and stumbled in this one DSCN1475 three years of dust collecting.... DSCN1477 ready to dissect.. assemble and join..... DSCN1476 91ACA90D 69820549 took me 6 hours to get that pin out done.... and confirmed.... This post has been edited by njccmd2002: Sep 21, 2017 - 2:20 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 22, 2014 - 9:14 PM |
hopefully its as easy as de-pin the one harness and just pin the new connectors.
Nov 23, 2014 - 8:48 AM |
Looks like fun.
Blast from the past there -------------------- |
Nov 23, 2014 - 9:10 AM |
hopefully its as easy as de-pin the one harness and just pin the new connectors. no, unfortunately, not... you see, the highlander being a 5 plug, has some signals going to juction boxes, and going to a specific signal in the ecu. In the rav 4 each individual signal goes to a specific point in the ECU. Maybe like 2 or 3 systems are like this. If i recall the heated 02 sensors, and the ignition coils, lol..... So i really have to open up all the harness..... Looks like fun. Blast from the past there it sure has given me a lot of headaches. But if you take the time and accept it for what it is, no more than a road map and yes those boxes are a blast from the past. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 26, 2014 - 10:50 PM |
peak preview of my wiring diagram, need to fix it, couple of connections and explanations. It prints in a 4x3 sheets of paper . (total of 12 now)
2grfecopy This post has been edited by njccmd2002: Sep 21, 2017 - 1:44 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 26, 2014 - 10:58 PM |
I can't say I envy you. Mr220v's prices seem more than fair to me since I don't even wanna look at the diagrams.
Nov 27, 2014 - 12:07 AM |
I can't say I envy you. Mr220v's prices seem more than fair to me since I don't even wanna look at the diagrams. And yes, however this is not a simple thing. Because, at best the engine needs at least 2 extra relays, that i need to find a place for them. And i need to understand the way the wiring would be, in case I need to troubleshoot. Hence my wiring diagram Plus and I tried to contact mr220v, never got a response, dont blame him, hes very busy. So i figured i wanted to learn. Im still making changes to the diagram.... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 27, 2014 - 10:49 AM |
There's some awesome weather proof relays on eBay with weather tight pigtail connectors that you can put literally anywhere without a special box.
Just search water proof relay on ebay or amazon and you'll find plenty. -------------------- |
Nov 27, 2014 - 11:14 PM |
Enthusiast Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
this was fun =D lol
good job! |
Nov 28, 2014 - 2:05 PM |
Worst part about wiring a car, is that you need to get the harnes for the ecu your going to use, lol changing from highlander to rav is not fun.....
Nov 28, 2014 - 3:14 PM |
You should have just gotten a whole half cut of a Camry or something man...
Nov 28, 2014 - 4:30 PM |
You should have just gotten a whole half cut of a Camry or something man... tought about it, it was 6000 on copart.com. I dont have a dealer license, and its a waste of money. i spent 2600 on a complete engine plus accessories plus 500 in incidentals. 3100 vs 6000 a lot of difference. plus i dont have time to part out a camry, and a yard will not pay 2900 for it, without the engine. Its a tough decision.... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 29, 2014 - 3:14 PM |
ok so i have mapped every wire in the harness, it really has been pain in the rear really.... as its been 2 full days. comparing the highlander and rav4 diagrams
DSCN1485 and the engine is like all gutted, lol.... DSCN1488 talk about the weight savings!! all the auto unnecessary crap... DSCN1487 now on to adding the celica bits, and theRav ecu connectors. This post has been edited by njccmd2002: Sep 21, 2017 - 3:04 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 29, 2014 - 3:53 PM |
Wow, I didn't realize a half cut 2GR Camry was still that much.
Nov 29, 2014 - 6:01 PM |
Wow, I didn't realize a half cut 2GR Camry was still that much. remember th v6 have the fancy electronics, most of the time. and all those add penny, i followed like 50 or 70 auctions at copart. got bored, and decided to just buy what i needed. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 30, 2014 - 2:19 PM |
ok, im ready to start the real wiring process..
If you know how to read a map, you know how to read wiring diagram. Its easy, the books are self explanatory. I was afraid all the time, because i never tought I could. Sure you can pay 500 to have someone do it. The 3sgte harness is a cookie compared to this monster there are 126+ wires going to the ECU. LOL But then when it comes troubleshooting time, if you dont know how it was made, then you are screwed. There is no halfassing it, i know where every solder goes, Im planning on adding a new fuse box, to accomodate new relays. Minor changes to the body wiring of the celica, but i would not be able to accomodate for all that if i have someone else do it... Plus i have trust issues.... Microsoft Paint is a Reals sport to play with wiring diagrams..... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 30, 2014 - 4:12 PM |
amazing amount of time and effort in a good wiring job, berto, and your killlllin it!!
13.6@108MPH, 5SFTE Powered |
Lo-Fi Version | Time is now: November 26th, 2024 - 5:57 PM |
