14 Pages V  « < 3 4 5 6 7 > »
> how to swap a 2grfe V6 into a st204, Toyota reliability, with less moving parts than a turbo
post Oct 26, 2014 - 11:41 AM
Syaoran
Joined Jan 4, '12
From US
Easier? No. Better? Yes. Cheaper? Hell naw.
For this build the very least you should get is a Sport 1000 from Haltech. That's over $1200 right there.
Make the stocker work for now and you could maybe later on use a standalone as a fuel/ignition controller for tuning purposes. A cheaper one, like a Megasquirt.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Oct 26, 2014 - 1:23 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (njccmd2002 @ Oct 26, 2014 - 8:13 AM) *
1. yes if you live in an area that does not do obd2 checks.
2001 Miata LS 5-speed
post Oct 26, 2014 - 2:09 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
But you won't pass OBD2 checks with a trans code stored...
post Oct 26, 2014 - 4:16 PM
well unless you guys chime in (i can pm my paypal), lol, no standalone guys sorry. And as far as the obd codes, working on a solution, possible to get around that transmission codes.
However i dont live in an obd2 check area, so no real worry for the moment.
I wont be spending money on tunes and dynos. period. but thanks for the encouragement.
so far so much money invested on this, that not really looking to invest more than i need to..
This post has been edited by njccmd2002: Oct 26, 2014 - 4:23 PM
post Oct 26, 2014 - 4:26 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just think though, you'll have the only one that we know of. That's exciting. redface.gif
post Oct 27, 2014 - 6:50 AM
well im going to post few pics here and there. obstacles to overcome....
DSCN1391
cut to this size to get more clearance
DSCN1392
then see this..
DSCN1396
bend to make this..
DSCN1397
unfortunately that tab, holds the power steering lines and will have to be relocated. But to answer everyones questions, smaller bolt is no longer in the way ...
DSCN1398
it does fit, and i have headers... (740 usd from Gouky)
couple of other things that i have to work... there is no space if you use the regular fans..
no chance for the a/c lines, and will have to use a custom combo...
DSCN1388
cant use the alternator with the stock fans and shrouds. need to get custom or creative..
DSCN1387
DSCN1390
relocate the dipstick, move it a little to the side
DSCN1383
clearance with oil cooler. but this one is ok...
DSCN1384
lower radiator hose, will probably have to come from the highlander, or a hybrid mix of both... because the celica hose interferes, so i need to get a hose union or something to mix em together
DSCN1394
upper radiator hose needs to be cut just a tad, careful where u cut it, so that it does not rub with engine..
DSCN1386
relocate the fusebox, you almost most have to it would be in the way of the hose..
DSCN1389
relocate power steering bracket for the reservoir
DSCN1393
then tackle the axle carrier bracket, going to have to weld something or go custom
DSCN1400
DSCN1399
as it is, the engine is 1 inch lower than the beams, or 3sge... so long plastic covers...... or maybe they will fit, only future will tell....
DSCN1395
so if this is not a clear description of what needs to be done to the car, i dont know what is...
This post has been edited by njccmd2002: Sep 21, 2017 - 12:51 AM
post Oct 27, 2014 - 9:54 AM
mkernz22
Joined May 10, '10
From MA
Is the PS axle going to fit with the header there? It might be the angle of the picture, but it looks like a pretty close call.. Props on all the work though, absolutely amazing.
This post has been edited by mkernz22: Oct 27, 2014 - 9:54 AM
post Oct 27, 2014 - 11:45 AM
it fits, it is proven by guoky... that was never an issue. but i know the pic looks bad...
post Oct 27, 2014 - 12:48 PM
Box
Joined Feb 23, '12
From Warrior, AL
You must have the patience of a saint, I'd have set everything on fire by now.
post Oct 27, 2014 - 3:56 PM
Syaoran
Joined Jan 4, '12
From US
My recommendation is to take out that double core radiator, keep the stock fans and a stock radiator. A good quality replacement.
Since you're going N/A you won't need a huge radiator at all, especially since you're probably using a GT-4 hood to clear the engine, right? The stock radiator is good enough for a 3S-GTE GT-4, should be good enough for a 2GR N/A. I'm actually considering removing mine and replacing it with a stock one, since I never really saw any huge improvements on cooling, my temperature problems turned out to be tuning related.
post Oct 27, 2014 - 4:55 PM
well some guys are running bigger radiators, since the engine requires higher pressure radiator cap. I had a stock radiator, and traded for this aluminum, in the future i may need it if i decide to supercharge.. however, i already have a solution planned....
post Nov 4, 2014 - 9:06 PM
just as suspected.
ps lines nightmare, A/c nightmare. I have to reroute these lines, as the mount is in the way.. and the a/c lines are to close to engine..
post Nov 4, 2014 - 9:17 PM
Box
Joined Feb 23, '12
From Warrior, AL
Who needs A/C in a convertible anyway? What real man needs power steering? See, just solved your problems. tongue.gif
post Nov 4, 2014 - 10:06 PM
perkyshadow
Joined Nov 13, '10
From Greenville, SC
Can you do stainless flex hoses? I don't know, I'm just asking! I replaced the clutch hose in my Z with a stainless flexible deal. Well... I ADDED the clutch line since it didn't actually have one to begin with!
post Nov 6, 2014 - 2:53 PM
Bitter
Joined Mar 11, '06
Electric power steering man...steal the system from a MR-2! You can mount the pump wherever and plumb the lines as needed.
post Nov 6, 2014 - 10:00 PM
i tought about it, even found several sites, and swaps for it. cost is about the same, but i have the pump, the belt, the pulleys, and notched the frame.
so the easiest way is to route the lines different ways, easy peasy. Working this week, so no updates for now.
just more work but i got it sorted out...
post Nov 12, 2014 - 9:28 PM
i have done several things but this takes the cake...
today i learned the wrong way, that i got a harness from the lexus es350. turns out the engine harness is not same as the engine room harness.
Purchased the harness in june, and I TOUGHT IT HAS both ecu clips to use for the rav 4, however, silly me, no engine harness.
turns out they are 2 different things. somehow the engine harness connects at the fuse box. lol.....
at a great cost.... 170 $$$ YIKES
when i saw headlights attached and yellow split looming with sensors, i said oh, oh...
well this harness has the small ecu plug 90980-12461 with wires, and a pedal connector 90980-12303 attached to it.
guess they are separated harness... I need both housings...
well i found today in a japanese site 90980-12396 is the number for the big housing.... Im eeying plugs on ebay, and made offer, if all else fails..
This really sets me back a whole deal... i was ready to start wiring....
And funny thing, this harness has like 3 more plugs that can be used for the pedals.
Probably sell them with pigtails and recoup money that way...
it has the fuse box, and smog sensor and airbag sensor :mad2:mad2
none of which i need.
post Nov 13, 2014 - 8:00 PM
ok so to give an update. and for the records.
im going to have to make a hybrid harness from the original highlander, which has 5 plug ecu, with the harness of the 2 plug ecu. I have the smaller plug, and may have to order the bigger plug..
DSCN1471
es350 harness, not engine, (has only one plug)
DSCN1470
need this...
90980-12396
also spent several days. with this.. (been done by a few at the mr2oc swaps....
DSCN1451
DSCN1452
DSCN1454
DSCN1455
DSCN1458
DSCN1465
did not take pics of the new parts, but there were a few to mount the belt, some bearings, and bolts..
DSCN1461
modified brackets for the power steering rack...
DSCN1466
made a mock of the rack...
DSCN1460
since lines are going behind, need a custom line for the high pressure side...
removed the vacuum lined, and hacked it in pieces to use for the low pressure ps line
also mocked the low pressure ps line..
DSCN1469
used a torch to bend
DSCN1467
DSCN1468
it has some leaks, but its ok. it will be fixed...
This post has been edited by njccmd2002: Sep 21, 2017 - 1:37 AM
post Nov 13, 2014 - 10:35 PM
Bitter
Joined Mar 11, '06
Fill the tubing with sand then cap the ends and then bend, or you can freeze water inside and then bend it before it melts.
post Nov 13, 2014 - 10:38 PM
nice tips, but i already bent it, wish i knew. the leaks are because it has been welded too.
Lo-Fi Version Time is now: November 23rd, 2024 - 10:04 AM
