Rear axel suspensions problem |
Aug 12, 2014 - 3:31 PM |
Enthusiast Joined Aug 12, '14 From Mountmellick Currently Offline Reputation: 0 (0%) |
Hi I have a 1997 st202 celica, as im driving down the road it feels as if the rear axel is loose or wabbling around. I have no idea what could be the problem and I am just wondering if anyone knows what could be causing this ?Thanks
Aug 18, 2014 - 3:14 PM |
Nope. Have you chcked it
Aug 22, 2014 - 5:32 PM |
ummm, i don't believe your car has a rear axle, but the hub or bearing could be bad.
Aug 22, 2014 - 8:36 PM |
Silly question, but are the lug nuts tight? It could be as simple as loose lug nuts, low on air pressure, or a very unbalanced/bad tire. Or it could be a bad while bearing like Mike mentioned, possibly even a bent rim.
Aug 29, 2014 - 11:45 AM |
Enthusiast Joined Jun 30, '14 From UK ESSEX Currently Offline Reputation: 0 (0%) |
check the Trailing Arm Bushes and while there check all the others
Lo-Fi Version | Time is now: November 27th, 2024 - 2:44 PM |
