> Is a 95 st's computer different from a 96 st (7afe) same engine bu
post Aug 16, 2014 - 6:07 PM
Yoni502
Joined Oct 11, '13
From 103062
My friend has a 95 st and I have 96 his revs almost to 7rpm mine just goes to 6rpm nd his also is way faster then mines I was thinking probably it has something to do with the computer.
post Aug 17, 2014 - 8:37 AM
yes.
post Aug 17, 2014 - 12:14 PM
Yoni502
Joined Oct 11, '13
From 103062
Would I be able to change it into my car? Nd if I can where can I find the ecu I'm still kinda new to this
post Aug 17, 2014 - 1:23 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
"his revs almost to 7rpm mine just goes to 6rpm"
by this do you mean that the redline on the rpm gauge is different?? this could just be because somebody switched the gauge cluster out with one that was for a 3sge.
doesn't necessarily mean the motor is different. if you're sure that it indeed has a 7afe.
the 94 and 95 are both still OBD1 but the pins on the ECU may not be in the same places and may be a different computer.
But if his is that much faster than yours I doubt it's just the computer. you could have a whole bunch of other issues effecting the performance of your motor.
Bust a Deal; Face the Wheel.
post Aug 17, 2014 - 2:03 PM
richee3
Joined Jun 29, '08
From Denver
OBDI/II depends on US or elsewhere. Outside of the US wouldn't be OBD. I can't say about JDM/Euro 7A's but I know USDM 7A's redline at 5,800 and 6,300, so no chance of flirting with 7k.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 17, 2014 - 6:40 PM
You can't switch ecus.
post Aug 17, 2014 - 6:42 PM
igpx12
Joined Jan 30, '14
From Cortland NY
Here's your main differences; 94-95 model vehicles are OBDI ready, this is the basics when it comes to our cars. 96+ vehicle models are OBDII ready which is US mandated for emissions testing. The differences between the two is that the OBDII ECUs are set up to run and manage the extra sensors that is required for emissions testing where as OBDI ECUs are missing the programming and circuitry to run those sensors.
To put it simply, if you live in a place where they plug your OBDII port into a computer come inspection time, it will fail if you do not have an OBDII ready motor and ECU with the extra sensors. Consider this most of all when looking at maybe dropping and OBDI ready engine into any 96+ model vehicle.
As for the rev differences, if you mean the tachometer range is different, it could be that someone swapped in another 6gc tach. If they are both the same tach ranges yet one revs higher still, it could be that the 94-95 ECUs have a different rev limiter range programmed than the 96+, so not really much you can do unless you can change ECUs and are able to lose the OBDII functionality.
For the power differences off the line, it could be a number of things, main one being engine maintenance over the years as our cars are almost 20 yrs old.
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Aug 17, 2014 - 7:11 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
not only that the 96+ is looking for a crank sensor signal that the 94-95 gets from inside the distributor. they will be a different signal.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: November 23rd, 2024 - 12:28 PM
