400 Pages V  « < 125 126 127 128 129 > »
> Teh Official "Dude Where's My Forum?" Thread, Brought to you by the minds of Box, and her fiancée, Lorelei
post Jun 7, 2016 - 3:12 PM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (njccmd2002 @ Jun 7, 2016 - 3:00 PM) *
El salvador
nice. well, welcome back!
post Jun 7, 2016 - 7:03 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
So I don't like the shaking from the front mount insert, but I do like the absolute lack of snapping torque steer shifting at 8,000 RPM, the ability to power on throttle in a sharp turn without wheel hop, and the loss of the rubber band shift feel. I might be able to live with this. More testing needed!
post Jun 8, 2016 - 10:14 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
El salvador
Pupusas?
-Alex {](O_o)[}
post Jun 8, 2016 - 1:01 PM
Sopa de patas and all that crap
post Jun 8, 2016 - 1:11 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (Bitter @ Jun 7, 2016 - 7:03 PM) *
As long as it doesn't shake bad enough that it feels/sounds like it's going to fall apart I think it's a worthwhile trade off.
2001 Miata LS 5-speed
post Jun 12, 2016 - 11:50 PM
Bitter
Joined Mar 11, '06
Repaired my pass side door check, door should no longer try to break shins! Driver side is next.
post Jun 14, 2016 - 2:48 PM
Box
Joined Feb 23, '12
From Warrior, AL
Today I ordered some Power Stop brake pads front and back along with 4 quarts of ACDelco SynchroMesh and 4 ounces of ACDelco LSD additive. Woooooo, guess what I get to do this weekend. tongue.gif
post Jun 14, 2016 - 6:14 PM
Bitter
Joined Mar 11, '06
I'm not really a fan of their ceramic pads, they really have a bad friction plateau that I dislike. As you apply more pedal they just don't stop any harder, which sucks, and is unlike semi-mets or my stoptech pads.
post Jun 14, 2016 - 8:15 PM
Box
Joined Feb 23, '12
From Warrior, AL
They were the cheapest performance pad, and I plan on chunking them when I eventually get around to putting on '98-02 spindles, calipers, and rotors. At any rate they'll be better than what's on there now.
post Jun 14, 2016 - 8:38 PM
Bitter
Joined Mar 11, '06
Fair enough, you'll see what I mean once you have them broken in, and probably hate it as much as I do. I drove a few cars with them at work and that was plenty, had some job grade ceramics on my Mazda when I got it and they felt pretty much exactly the same. I wouldn't call Power Stop pads performance pads, not if stopping is the performance, but they'll do well enough I guess.
post Jun 14, 2016 - 9:55 PM
Box
Joined Feb 23, '12
From Warrior, AL
I hate touchy brakes, oh well figured it'd be better than economy grade pads and I didn't want to spend the money on the StopTech Sport or Raybestos EHT pads only to turn around and throw them away in a few months. Once it cools down enough outside I'll be going to Pull-A-Part when they have a few late 4th gens to takes the brakes off of.
post Jun 16, 2016 - 6:52 AM
ClevelandGaint
Joined Feb 12, '13
From Cleveland
What sw20 mr2 forums are actually worth my time? I been hearing mixed reviews, any thoughts?
post Jun 16, 2016 - 8:34 PM
Box
Joined Feb 23, '12
From Warrior, AL
MR2OC I believe is one of the good ones.
Transmission fluid and LSD additive arrived today, stopped by Hell-Mart and grabbed two quarts of Valvoline 80W-90 so at least now I'm ready to change all that.
post Jun 16, 2016 - 9:24 PM
Bitter
Joined Mar 11, '06
Ordered my new driver side door check, $88 and it'll be in at the dealer on Tuesday. There is indeed a superseded part number some maybe it's a revised/improved design with better longevity! When the passenger wears out again I'll just get a new one for that side too.
post Jun 17, 2016 - 1:06 AM
Box
Joined Feb 23, '12
From Warrior, AL
post Jun 17, 2016 - 6:06 PM
Box
Joined Feb 23, '12
From Warrior, AL
Brake pads arrived today and I like how nowhere on or inside the box is the following break-in procedure mentioned: http://www.powerstop.com/brake-pad-break-in-procedure/
Meh, so long as they work ok enough until can get the brake conversion done I'll be content.
post Jun 19, 2016 - 5:52 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just sold the old set of rims and tires for $150, so wooo car parts money and less stuff to trip over.
post Jun 20, 2016 - 9:26 AM
ClevelandGaint
Joined Feb 12, '13
From Cleveland
Did a tuneup on the mr2, now waiting for my slave cylinder that was supposed to be here yesterday to show up today so i can get that installed.
post Jun 20, 2016 - 1:36 PM
Box
Joined Feb 23, '12
From Warrior, AL
So about to order the rest of the stuff I need so then every last nitpicky thing will be over with and I'll know where everything stands. I was thinking about it the other night, but I'm not sure if I should just stay with DEX-COOL or attempt changing it over. So far 20 years of it and everything is still in good shape and operates as it should, so I feel as if I'd be tempting fate by trying to switch it over. Though supposedly the green anti-freezes out today are compatible with any and all coolants. I'm thinking I should just run a 70% distilled water and 30% DEX-COOL mix and call it real.
This post has been edited by Box: Jun 20, 2016 - 1:37 PM
post Jun 20, 2016 - 2:09 PM
ClevelandGaint
Joined Feb 12, '13
From Cleveland
And forgot, i did the valve cover gasket as well
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 23rd, 2025 - 7:26 PM
