> Quick question, pcm/ecu
post Aug 18, 2014 - 4:18 PM
yaj204
Joined Nov 29, '07
From california, marysville
Where is the ground for the pcm/ecu located?
post Aug 18, 2014 - 10:25 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
there are 4 different grounds on the ecu plugs E01 white/black, E1 brown, E02 white/black, E2 brown. which pin position varies depending on which year you have but they all go up through the wirelimb out the passenger side firewall conduit and come out and bolt to the intake manifold to a bolt between injecter 2 and 3. it's easier to see from underneath.
from what I understand there is supposed to be a braided ground strap running from one of the bolts on the manifold to the firewall.
Bust a Deal; Face the Wheel.
post Aug 18, 2014 - 11:39 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
look on the back of the intake manifold. you should see the grounds bolted down there
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 19, 2014 - 6:42 AM
yaj204
Joined Nov 29, '07
Thanks alot... Every helpful
Lo-Fi Version Time is now: November 27th, 2024 - 5:51 PM
