> Ajusting the valve clerance`?, As the topic says
post Aug 25, 2014 - 8:42 AM
Tort1llaboy
Joined Nov 25, '13
From Norway
As the topic says, How do you ajust the valves on 7afe?
post Aug 25, 2014 - 5:45 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
its not easy but its the exact same way you do the 5S-FE, 1MZ, 3MZ, 2JZ, and several other toyota engines. you can look for a detailed guide for those.
in a nutshell there are 2 SST (special tools) that you can use. One grabs the cam shaft and pushes down on the bucket. the other helps pop out the shim. I have tried to use them and its not easy.
What I ended up doing was just taking out the camshaft and changing the shims. I also replaced the water pump and timing belt.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: November 26th, 2024 - 8:16 AM
