WTB [URGENT!!!] AC/alternator harness pigtail, mine melted.... |
Aug 25, 2014 - 6:05 PM |
Enthusiast Joined Jul 10, '08 From Tampa, FL Currently Offline Reputation: 8 (100%) |
I need AC/alternator harness pigtail (assuming that GT and ST have same harness). with all the connectors intact - the alternator plug, AC plug and one more (not sure what it is?). Mine in car melted and right now is being held together by spit...
I need this very urgently because, as of now, my alternator is not charging battery at 100% (my battery light on dash is on)!!! I was gone for a while and just realized that 6GC does not allow linking pics from photobucket anymore but I can send you a pic of exactly what I need. THX -------------------- '94 ST
Aug 25, 2014 - 9:10 PM |
so use another image host.
the other sensor is probably the oil pressure sensor. I have the oil pressure sensor plug and a pigtail. I dont have the AC or alternator. but i do have the part numbers for them. you can get them from toyota alternator is 90980-11349 AC plug is 90980- (crap its at home and im on travel) -------------------- 2001 Celica GT-S Turbo
Aug 25, 2014 - 11:25 PM |
Enthusiast Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
also if you need one right away the Camry has the same 2.2L motor and the Corolla the 1.8L, dozens of them in the salvage yard.
the wirelimb is not the same but it has many of the same plug connectors, they just may be using different color wires. -------------------- Bust a Deal; Face the Wheel.
Aug 26, 2014 - 5:21 PM |
BUMP. I can't believe that with so many members nationwide nobody has an access to a wrecked Celica/Corolla...
Aug 26, 2014 - 5:57 PM |
You should be more worried about what caused your plugs to melt....there must be something up with your car and the same thing will happen if you replace them..
This post has been edited by mkernz22: Aug 26, 2014 - 5:57 PM |
Aug 26, 2014 - 6:09 PM |
I know exactly what did it: aftermarket headers. Even though I have wrapped them in thermal wrap they still, I guess, generate too much heat... I'm already thinking about creating some sort of a heat shield on the alternator side.
Lo-Fi Version | Time is now: November 26th, 2024 - 6:25 AM |
