> Apexi safc2 vs Apexi fc neo
post Aug 30, 2014 - 7:14 AM
doory100
Joined Jun 21, '14
From Ottawa, Ontario, Canada
I have found these two controllers for the same price. The Apexi web site has the neo as the new safc converter and says it works with the celica. I am wondering which one I should get? I have a 95' celica GT-S 2.2L 5sfe. Also what are the differences if any?
post Aug 30, 2014 - 11:15 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
My understanding is that the Neo allows for more adjustments with finer controls and has a nicer display and interface. The SAFC2 is pretty dated, but the VFD display is readable in daylight.
Just remember that as you pull fuel away with the AFC you're doing it by altering the MAP signal to the PCM, so it's going to also adjust the timing table to match the MAP signal it's seeing. Pull fuel away via MAP adds timing, adding fuel via MAP pulls timing. You're just 'tricking' the computer into thinking there's more or less airflow so that it adds more or less fuel than it normally would, so naturally it's going to adjust everything else to match the airflow it's seeing or thinks it's seeing.
post Aug 30, 2014 - 11:25 AM
doory100
Joined Jun 21, '14
So your saying I should go with the neo and it will work with a na 5sfe? I am going to get some 264 grinds done at delta cams. will this work good in combination with the cams?
Thanks
post Aug 30, 2014 - 2:18 PM
Bitter
Joined Mar 11, '06
The Neo is the newer one and if they're the same price get it. You'll need a way to watch the AFR when tuning as well.
post Aug 30, 2014 - 6:25 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
basics for cammed 5s:
1. Camshafts
2. Shims
3. SAFC
4. Wideband A/F gauge
エキサイティングカーレーシングチーム!
post Aug 31, 2014 - 7:07 AM
doory100
Joined Jun 21, '14
QUOTE (Tigawoods @ Aug 30, 2014 - 7:25 PM) *
1. Camshafts
2. Shims
3. SAFC
its all lined up. what about the injectors, should i get rx7 injectors. I can adjust the amount of fuel with the apexi neo right?
what do these shims look like because i can probably make them myself at work
post Sep 5, 2014 - 9:05 AM
doory100
Joined Jun 21, '14
what about fuel injectors? Will I need them also?
post Sep 5, 2014 - 11:08 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
i do not think you will need to change injectors. safc will aid in the fuel management. guys often take the abilities of the stock injector for granted.
post Sep 7, 2014 - 7:51 PM
doory100
Joined Jun 21, '14
I found this Zeitronix wideband o2 sesor for $100 on kijiji and I was wondering if there any good. Also how does it compare to the aem augo? This is the Zt-2. Here is a link to there website.
http://www.zeitronix.com/Products/zt2/zt2.shtml
This post has been edited by doory100: Sep 7, 2014 - 9:30 PM
Lo-Fi Version Time is now: December 4th, 2024 - 8:09 PM
