![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) ![]() |
as the title states interior lights (dome and door) do not work along with the clock. fuses seem to check out. i think it has to do with the integration really located in the inter fuse box... any helpful info is greatly appreciated.
thanks! This post has been edited by garin: Sep 3, 2014 - 5:01 PM -------------------- |
Enthusiast ![]() ![]() Joined Jul 1, '14 From Hawaii Currently Offline Reputation: 3 (100%) ![]() |
as the title states interior lights (dome and door) do not work along with the clock. fuses seem to check out. i think it has to do with the integration really located in the inter fuse box... any helpful info is greatly appreciated. thanks! Try swapping a different 10amp fuse into the dome light fuse slot first replacing a fuse is easier than the relay, so why not try it first haha One of my 7.5amp fuses looked perfect. But it was blown. Spent extra time on other things rather than replacing a fuse.... Very annoying stuff lol Also by swapping I mean take a fuse from another circuit in the fuse box Edit: forgot to mention, try seeing if the light in the rear works the switched one in the back on the left. If it doesn't turn on, its probably the fuse/a short(which would blow the fuse). But if it does, its probably the integration relay. This post has been edited by Noahwhite2014: Sep 4, 2014 - 7:22 AM |
Lo-Fi Version | Time is now: February 19th, 2025 - 5:34 PM |
