> Diagnostic cable ?
post Sep 16, 2014 - 4:29 PM
dvines
Joined Jul 12, '12
From Carshalton/Surrey/UK
Hi
Is there a diganostic cable available that will enable you to plug into a laptop and read codes, capture live data etc.?
I have a 1995 Celica GT convertible. 2.0 auto, Jap import. 3S-GE engine I think...
Have seen this on Ebay but have no idea if it will fit, and if it does what do I couple it to ? ( I have a Bluetooth OBDII dongle for my phone I used to use on a much newer Subaru Legacy)
http://www.ebay.co.uk/itm//151042793957
post Sep 16, 2014 - 6:35 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Yes and no. Yes that will plug into your port, but no it won't allow your OBD2 setup to read codes or data since a 1995 doesn't have OBD2 communications protocols.
post Sep 16, 2014 - 7:19 PM
richee3
Joined Jun 29, '08
From Denver
There will be a plug in the engine bay with the 3S-GE labeled "DIAGNOSTIC." Your 5S should have the same plug. You can scan codes by jumping two ports in this box. As far as capturing live data, it should be the same as trying to scan this information from an OBDI equipped car.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 16, 2014 - 9:30 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
im pretty sure I've seen an ODB1 to ODB2 adapter that you can plug onto that usb to ODB2 cable, then you need the software to run it. I've looked into getting it but im not sure all the details yet.
they have the Toyota TIS software on the bittorent sites. not yet sure if we can get it to work for ODB1 or not.
This post has been edited by VavAlephVav: Sep 16, 2014 - 9:30 PM
Bust a Deal; Face the Wheel.
post Sep 16, 2014 - 11:28 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
he also has a Jap spec ECU. they dont have ODB like USDM
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 16, 2014 - 11:39 PM
Bitter
Joined Mar 11, '06
It should still blink the same codes at least right and reading the voltages at the terminals will still tell you rough fuel trims and oxygen sensor output, correct?
Lo-Fi Version Time is now: December 2nd, 2024 - 6:07 AM
