Where can I buy cams ready to bolt-in! 5sfe, I'm looking for some more aggressive cams ( im located in Australi |
Oct 1, 2014 - 1:52 AM |
Enthusiast Joined Sep 30, '14 From Australia Currently Offline Reputation: 0 (0%) |
This is my first post by the way, was also wondering if there are any aftermarket ecu options for a 5sfe
Oct 1, 2014 - 3:43 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
Welcome aussie, you are limited with the 5S-FE head design, where you have one cam running of another cam (DOHC but with 1 cam pulley)
On a side note. 3S-GE & 3S-GTE have a much better range since its true DOHC with 1 cam pulley per camshaft &the interchangeability between the 2 engines. But wont fit in a 5S-FE. Having said that you can buy regrind cams for the 5S-FE. Best to have a search here in the engine section for webcams & colt cams - they are USA companies, pressure2, tigawoods & 6G96GT. http://www.6gc.net/forums/index.php?showtopic=80857&hl They are aftermarket & piggyback ecus that can work with the 5S-FE, but not your 'plug & play' type, if thats what you are looking for. -------------------- |
Oct 1, 2014 - 5:23 AM |
Enthusiast Joined Jun 21, '14 From Ottawa, Ontario, Canada Currently Offline Reputation: 0 (0%) |
Delta cams does 264 regrinds for $150 per cam and that's the cheapest I found. I'm going to do this to my 95 when I do the head gasket. Also I have a apexi AFC neo. Just put in a stage three clutch on the weekend.
Check out my posts if you are looking for answers. -------------------- |
Oct 1, 2014 - 6:44 AM |
Thanks for the response, doori would u have a link to the apexi afc neo u purchased, ill probably take a pass on the cams for the moment as im unsure on where to get them regrinded, also rusty what products are u talking about and would I have to replace the current ecu and wire up the new one I purchase? Thanks in advance!
Oct 1, 2014 - 3:33 PM |
Just google the apexi neo, and also delta cams. the neo is useless unless your doing some upgrades. as for the cams I called around and that was the lowest price. the guy their said that i would see a 15% gain in HP. just go pull some off a camry or a rav4. the ones i'm sending out for the regrind are off a rav4 3fse. you can spend $450 each on some web cams 293. but then you will probably have to upgrade you engine a bit more.
Oct 1, 2014 - 3:51 PM |
Enthusiast Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
They have a "drop in" profile where you will only need an intake and an exhaust header to make it work. Anything more aggressive and you will need spring and shims, and new injectors. ect.
-------------------- Bust a Deal; Face the Wheel.
Oct 1, 2014 - 4:57 PM |
Oct 1, 2014 - 7:04 PM |
Oct 3, 2014 - 11:17 PM |
Just the ones others have mentioned, but any will need some sort of rewiring
Oct 20, 2014 - 6:40 AM |
Enthusiast Joined Apr 18, '14 From North hollywood ca Currently Offline Reputation: 0 (0%) |
Will the 3sge head fit on a 5sfe ?
Lo-Fi Version | Time is now: December 1st, 2024 - 2:44 PM |
