> 3rd Gen 3sgte wiring with a tweakd harness, clutch start swItch
post Oct 5, 2014 - 10:27 AM
silverceli
Joined Nov 10, '13
From nj
Ok here's the story I ordered a tweakd harness told them exactly what I needed anyway I get my harness and some plugs don't fit long story gotta call them Monday anyway,does anyone know if u have to rewire in the clutch start swItch or should it already b wired in I tried to start my car after new harness install (btw it ran fine b4 I took the old harness out)and the car won't crank I get nothing when I turn the key any help would b appreciated
post Oct 15, 2014 - 6:53 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
Clutch switch is wired from the starter fuse in the interior fuse box to the ignition starter switch. Car won't start with out the the complete circuit. If the wiring is correct and the plug is wrong just solder the wires to the switch together. Just make sure you start your car safely (out of gear foot on brake).
post Oct 20, 2014 - 2:43 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (garin @ Oct 15, 2014 - 5:53 PM) *
Exactly what I had to do for my 3SGE swap. Soldered in a line from the starter switch to the relay point in the engine bay.
Works like a charm, just have to make sure its never left in gear (which I was used to before, because I had command start biggrin.gif )
post Oct 23, 2014 - 6:57 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (KAOS @ Oct 20, 2014 - 3:43 PM) *
... And all your friends are like woah what's going on here he can start his car without the clutch pushed in
I think it's your best bet... Just make sure the wires are tucked so they don't get caught up when you shift
post Oct 23, 2014 - 7:44 PM
silverceli
Joined Nov 10, '13
From nj
I figured it out the clutch start switch came loose some how but it's fixed thanks for the replies tho
Lo-Fi Version Time is now: December 2nd, 2024 - 7:56 AM
