Custom 5SFE Intake Manifold Project |
May 12, 2015 - 4:36 PM |
Enthusiast Joined Jun 21, '14 From Ottawa, Ontario, Canada Currently Offline Reputation: 0 (0%) |
Finally getting the intake welded together. starting to look good!!
the velocity stacks I made don't look to bad... -------------------- |
May 21, 2015 - 8:08 PM |
I have run into a problem. My intake fits but the plenum is right against the fire wall. I have not welded the plenum onto the intake just yet. Im wondering how far from the fire wall it needs to be? Im about 2 days from scrapping the whole intake project!!
This post has been edited by doory100: May 21, 2015 - 8:09 PM -------------------- |
May 21, 2015 - 9:23 PM |
Depends how solid your mounts are. Get a big wad of Playdo or similar modeling clay and put a big wad on the back of the intake manifold touching the firewall with some cardboard under it (so it won't fall out) and go for a spirited drive, see how much smoosh there is and then add 20-30% to that figure and you should have a distance.
May 22, 2015 - 12:31 PM |
Enthusiast Joined Dec 27, '11 From minnesota Currently Offline Reputation: 0 (0%) |
Not sure how close yours is but this was the 3sge in my corolla, I had a rear solid poly mount and a front rubber filled poly mount. It never hit. Also you can maybe put a stopper on your motor mount if you don't want to damage the manifold or maybe change the radius slightly.
May 28, 2015 - 12:47 PM |
Here is my new clearance.
I'm modifying the intake and I need some thoughts Is this to big or should I go with this ? -------------------- |
May 28, 2015 - 3:09 PM |
Do some math on plenum volume, runner length, and the RPM you want peak power to be around.
May 28, 2015 - 5:24 PM |
Jun 9, 2015 - 3:52 PM |
Jun 10, 2015 - 2:48 PM |
Kinda cause one provides just filtered air while the other provides vacuum.
Jun 10, 2015 - 6:32 PM |
I have found a use for it
Jun 14, 2015 - 1:41 PM |
Jun 14, 2015 - 1:55 PM |
Enthusiast Joined Aug 25, '08 From England Currently Offline Reputation: 1 (100%) |
I have been looking at a similar thing for my project build, but was thinking about a side feed centre feed inlet manifold.......if that makes sense, a bit like the one in this picture, but with the inlet part veering off to the passenger side.
See if I can figure out a way of doing it......need to break out the calculator. This post has been edited by Nial: Jun 14, 2015 - 2:23 PM -------------------- |
Jun 14, 2015 - 6:55 PM |
hopefully it will be painted by tomorrow
Jul 4, 2015 - 8:00 PM |
please delete this thread. the intake was a bust!!!
Jul 4, 2015 - 8:08 PM |
No need to delete it. How was the intake a bust? Let's keep this thread open and keep bouncing ideas around on how to improve the intake.
Jul 5, 2015 - 6:42 PM |
the pipe and the TB together were inches away from the distributor. It was not on the car and i forgot it was going to be there. plus it should have been closer and taller. I really wanted the 2.5" TB and the intake to work. I just dont have any time to go back to the drawing board.
Jul 5, 2015 - 7:22 PM |
I would still keep it in case you do have some time in the future. Its also nice to have something that only needs slight modification to have work.
Aug 5, 2015 - 11:06 AM |
Is this a waste of time or should I go for it? The runners look a bit to long! TB does not clear the firewall
Aug 18, 2015 - 8:47 PM |
Intake is done and ready to go in tomorrow... I hope!!
Going to repaint the intake body after the Celica stencil dries. Using this weld to add pems for the bolts. Works incredibly well. This post has been edited by doory100: Aug 18, 2015 - 8:47 PM -------------------- |
Aug 19, 2015 - 9:30 PM |
Lo-Fi Version | Time is now: November 25th, 2024 - 10:07 PM |
