> Integration Relay Testing, How do you check if yours is bad?
post Oct 6, 2014 - 6:13 AM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
Im not sure what would happen if my integration relay was an issue, but I'm having some electrical problems in my 1994 st USDM spec hatchback. So the integration relay is the brown box. Does anyone know how to test it? I'm going to be taking it out and just visually inspecting it. If its not the integration relay I'm starting to think the root of my problems is the inner fusebox which ill check afterwards.
post Oct 9, 2014 - 12:43 PM
you need a meter, or tester.
Lo-Fi Version Time is now: November 29th, 2024 - 7:41 AM
