i have the parts at home. unfortunately it would mean rear seat delete. I will base it of the hard dog for the MR2. I just have to get some time off...
Awesome, should help stiffen the chassis and make it safer all at the same time. I look forward to some autocross and/or some track day vids.
freshly painted wiper arms, and new toys...
036AB6F2 ![]() 176E920C ![]() This post has been edited by njccmd2002: Sep 25, 2017 - 2:54 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Clutch slave and a sticker, good times.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) ![]() |
What did you choose for those spherical bearings. I've been thinking of replacing the rubber bushings. Also, isn't prime awesome??
my shifting sucks, so i have decided to try anything, even going to a regular shifter. The bushing from prime was 18 bucks, and the bearings where 45. worth a try. if not then must be the cables, need lube? im tired of having to fight to shift..
oh and the slave, was worth a try, because i have a regular s54 slave.. so will see. prime is awesome. at one point in time i may change the bearing, but that is a long story -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Perhaps could get someone to move the shift selector through the gears while you look under the car, see if it's binding anywhere.
What cables are you using ?
ST 205 cables,
to solve the shifter cables from hitting the header, i did it by trying to move the cable to the side with this... 13FAB43F ![]() and then covering with shielding covers.. up to 3000 heat... 3CC7C988 ![]() The cable is not compressed is loose, so this would not be a reason to bind, assuming cables need lube? and other stuff. This post has been edited by njccmd2002: Sep 25, 2017 - 3:12 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
finished and painted gt4 hood...
55508790 ![]() 4E44842A ![]() an extra trunk lid is always very good.... 2777459C ![]() This post has been edited by njccmd2002: Sep 25, 2017 - 2:57 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Looking good.
Fiberglass decklid? -------------------- 2001 Miata LS 5-speed
Spare decklid. Im stripping rattle can job. To paint black. This one has no holes made by me
Hood came out great minus the runs -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Ah ok, guess that's seran wrap and rust.
![]() -------------------- 2001 Miata LS 5-speed
just ordered a replacement ECU. Will have this ECU modified to increase the rev to 7200 and remove all transmission DTC and Evap codes!!!!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) ![]() |
Nice! So, no check engine lights?
-------------------- ~bloodMoney
Thats the plan
If you follow this thread. Shifting has improved...
F04E39D9 ![]() 187802BB ![]() E5B7C32A ![]() This post has been edited by njccmd2002: Sep 25, 2017 - 2:59 AM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Amazing how one little part can make all the difference.
![]() Enthusiast ![]() Joined Oct 17, '16 From Grand Rapids, MI Currently Offline Reputation: 0 (0%) ![]() |
That tach adapter is primarily for engine swaps right? My tachometer is broken, and I'm looking to take it apart and diagnose the problem soon. From some online research, it seems like the problem should be solved by just replacing the internal capacitors, but that digital adapter seems interesting (although pretty expensive). I understand that you solved a different problem when working on your tach, but since you had it taken all apart and everything, do you know if the capacitors inside the tach are a common failure point? I apologize if this question isn't relevant to your build, you obviously know a lot about these cars so I figured it wouldn't hurt to ask. Just trying to do the job right the first time I remove the gauge cluster from my car.
We have brass ones in Stacy's car... They made a world of difference.
Lo-Fi Version | Time is now: April 22nd, 2025 - 5:48 PM |
