17 Pages V  « < 7 8 9 10 11 > »
> 2GRFE v6 convertible
post Nov 8, 2016 - 9:54 PM
QUOTE (Bushmatic @ Nov 8, 2016 - 1:39 PM) *
That tach adapter is primarily for engine swaps right? My tachometer is broken, and I'm looking to take it apart and diagnose the problem soon. From some online research, it seems like the problem should be solved by just replacing the internal capacitors, but that digital adapter seems interesting (although pretty expensive). I understand that you solved a different problem when working on your tach, but since you had it taken all apart and everything, do you know if the capacitors inside the tach are a common failure point? I apologize if this question isn't relevant to your build, you obviously know a lot about these cars so I figured it wouldn't hurt to ask. Just trying to do the job right the first time I remove the gauge cluster from my car.
it would be easier to install a new tach. they are easy to install
changing capacitors may help. but first make sure the tach is getting a signal. the easier way would be to put a used working tach
post Nov 11, 2016 - 2:37 PM
Bushmatic
Joined Oct 17, '16
From Grand Rapids, MI
QUOTE (njccmd2002 @ Nov 8, 2016 - 9:54 PM) *
They may be easy to install, but they are impossible find online.... Unless someone has a spare lying around they'd be willing to sell to me for cheap, I think I'm going to have to solve my problem with only my own broken tach to work with.
QUOTE (TimeslideZ @ Apr 22, 2017 - 4:49 PM) *
I currently live in MN and have always been a Toyota my whole life.
post Nov 12, 2016 - 2:35 PM
Get a clusteter from the yard. Or ebay for about 50 bucks
post Nov 13, 2016 - 4:32 PM
mcoury
Joined Oct 27, '16
From Detroit, Mi
I have a tach that's just sitting around.....
mjcoury@gmail.com
post Nov 18, 2016 - 10:57 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Is the inside of the cluster modular like it is with the Corolla? In that cluster the speedo and tach are like whole units that just bolt into the carrier and circuit board.
post Nov 22, 2016 - 6:12 AM
Lexa666
Joined Mar 15, '10
From Russia
post Nov 22, 2016 - 6:53 AM
Thanks. Unfortunately 2gr never picked up as a swap
post Nov 22, 2016 - 12:18 PM
Cost is the main factor.
Even with the MR2 guys, there aren't many.
Stef and I have done 3 2gr swaps in MR2s, they are not cheap but hella fun to drive.
post Nov 22, 2016 - 10:10 PM
Super fun to drive
post Sep 25, 2017 - 4:28 AM
well i decided to update the thread, in the last year, will put a summary of what happened.
GT4 hood is no more, i still have it, in storage but is toasted. forgot to lock it, and had no hook at the time...
then decided to do something very stupid...
cut the OEM hood, did not look nice, looked like a civic.. It did not clear the engine, so i winged it...
Took the car to an autocross, event. Made Second place..... woot woot. Only 2 cars in FWD
Found a second replacement hood... cut the bracing and rewelded it. it was loose....
It made the hood wavy, but oh well, it works....
Then i got bored and removed some rare things to sell.... lol.
rally lamp, sold....
Con Light... I gave it away...
Alarm system, well, its there collecting dust, and i dont regret it...
Then sent the car to be retinted before a big step..
Welded in a Custom Roll bar, and deleted the rear seats...
Then decided to protect the engine.... Moroso oil pain, very expensive....
And then i created version 2 of the pedal bracket, to adjust the height...
still needs to be a version 3... but ill get there...
lastly the most anticipated event... the Modified ECu, No more check engine light....
I still have the second ECU as a spare.... But this ecu makes driving better by increasing redline...
This post has been edited by njccmd2002: Sep 25, 2017 - 4:29 AM
post Sep 25, 2017 - 4:41 AM
The day i hounded facebook, and made Mike Thoma Upset!!! Tag Him!!!
Put in new brake pads....
And Added Toyos R888, wrapping enkei wheels,
Took the car to the first track day, a humbling experience. I dont know how to drive it, and needs more tweaking... lol...
Unfortunately keep the car in storage, as i dont want the sun to damage the top and water get in the car, and etc. Why, because I care.... and also
this behemoth is taking up its space...
This post has been edited by njccmd2002: Sep 25, 2017 - 4:41 AM
post Sep 25, 2017 - 9:16 AM
cheela
Joined Feb 2, '07
From Berlin, WI
coming together really well now. get some more track time and you can only improve from there.
LOL at the honda hood.
and is that ur new DD? looks comfy and fun.
post Sep 25, 2017 - 9:20 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
An SC?!
That's going to take a lot of $$$ to modify into a proper sports car... lol
~bloodMoney
post Sep 25, 2017 - 9:22 AM
Lol. Not mine. I have a 16 y/o that drives. Needed to get a tank
post Sep 25, 2017 - 9:48 AM
cheela
Joined Feb 2, '07
From Berlin, WI
you know what cars are tanks? 6gc's.
but should be good for her then. always scary to get them on the road but if you taught her then no worries. lol
post Sep 26, 2017 - 2:58 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Hey, let's get one thing straight....
Things drive into me. I can't help that.
ON TOPIC: I can't believe she's 16 already. For some reason, she never made it past 9 in my head....
~bloodMoney
post Sep 26, 2017 - 4:15 PM
Lol... off to college in 2 years. Time flies. Enjoy the most you can... after college more money for car parrs.... yeah!
post Sep 26, 2017 - 5:33 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (njccmd2002 @ Sep 25, 2017 - 4:41 AM) *
Hey look, the worst car in the world as decided by Top Gear!
2001 Miata LS 5-speed
post Sep 26, 2017 - 7:28 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
You should of cut and welded the hood section from an late spec eclipse...
post Sep 26, 2017 - 9:04 PM
no, then it wont look like a celica. i tought about it, but no.
Lo-Fi Version Time is now: April 22nd, 2025 - 5:45 PM
