![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) ![]() |
2grfse is for RWD vehicles. its much better from what i hear mmmMMMmmmm... Dual fuel injection.... Daniel: Come get it. Hell, I'll even throw in an E153! -------------------- ~bloodMoney
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) ![]() |
NOOOOO! my v6!!!
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
SOMEBODY come get this ****! At this point, I really don't care who...
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) ![]() |
I would but I think someone else here already has dibs on one of them.
I have a 3mz if you want...
ok so one of the things that i hate about this swap, is the space. there is none...
my leak ended up being power steering fluid, did not realize that until too late... i drove the car 15 seconds into the garage with out it, and the pump screeches even with new fluid. the leak was fixed, but the pump needs replace... so i ordered a new pump on fleabay, and it came dirty as crap..,,, after washing it looked better... ![]() of course me thinking it was going to be a 2 hour job, after the mess i made with ps oil, and unable to reach 1 bolt. realized that i needed to lower the engine.... sucks.... ![]() maybe time to modify the mount... ![]() i cannot even reach from this top part.... but there is more space.... ![]() ill try again tomorrow, im concerned ill need to drop the subframe a few inches too, this will let me reroute the lower pressure hose..... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Such a pain.
it really is.... but it is what it is....
Are you able to access the rear bank for spark plug replacement? Or will this be another thing where you'll need to drop the engine a little to get to them?
I'm sure it's worth it, but man... What a pain in the ass. -------------------- ~bloodMoney
yes but its a tight space. thats why the plugs are changed when the clutch needs change..... lol
so after 6 hours of several finnagles, and cussing.... ![]() able to get it out.. used a 1/4 socket, with medium size 14mm, to finally loosen second bolt. then droped subframe 1/4 inch, also disconnected the sway bar, and also tie rod, and moved steering to left. to finally get it out.... ![]() I had forgotten how tight it was.... lol.. next to put it back together..... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
2 hours to install a dam ps pump.... im off tomorrow, hope to button it up
Huzzah! Now just never let this one dye.
Enthusiast ![]() ![]() Joined Jun 9, '16 From Minnesota Currently Offline Reputation: 0 (0%) ![]() |
Beyond the maintenance, is there a next step for the car?
Beyond the maintenance, is there a next step for the car? like what? rwd, not likely, or awd never... anyways today was very productive. after the stupid ps pump was in ![]() decided to take the old ps low pressure line, and toss it... ![]() went to work and got my line straightened.. ![]() after a few bends here and there obtained this... ![]() had to make a bead to avoid hoses slipping ![]() tossed the old one in the recycle ![]() this is not paint, i tried something new. i used shrink tubing, protects better. but pain to do... ![]() makes it look better, but the curves suck... ![]() gives it a more professional look.. ![]() i also fixed some loose wiring from the radiator relays... and now i have to make a new mount for the reservoir, i was going to use aftermarket, but will stay oem ![]() probably need a cleaner one... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
get it all set and hopefully won't have to touch the engine for a longgggg time. haha.
thats the plan, next stop is Air conditioning..
I like the shrink tube idea...
That PS line came out great! I don't have the patience for things like that. -------------------- ~bloodMoney
im stuck with bleeding the air on the ps system...
Tried having the nose of the car lifted while turning the wheel lock to lock, and the engine off, topping it off as needed?
This post has been edited by Box: Feb 21, 2018 - 2:39 PM -------------------- 2001 Miata LS 5-speed
been there done that, keeps sucking air.. lol im starting to belive something else was damaged
Lo-Fi Version | Time is now: April 22nd, 2025 - 10:26 PM |
