2GRFE v6 convertible |
Jan 23, 2019 - 8:01 PM |
i did not have time to check on it today, runs like a motorcycle and check engine blips, serious loss of power. so yeah, thats my bump again for today
Jan 27, 2019 - 6:56 PM |
I'll take fueling issue for $500 Alex.
Jan 27, 2019 - 10:03 PM |
nope.....
it was spark plugs. thats all i did... pain in the ass to get to the rear bank.. had to test the coils one by one... i was scared it was something else, the gremlins may come back anyways... ill see. https://i.imgur.com/3vZzy8h.mp4 This post has been edited by njccmd2002: Jan 27, 2019 - 10:04 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jan 27, 2019 - 10:05 PM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
Glad it was something simple...well for the most part aside from getting into the back there. lol
-------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Jan 29, 2019 - 4:04 PM |
Enthusiast Joined Mar 4, '18 From Oregon Currently Offline Reputation: 0 (0%) |
I think thats one of the main reason i wouldn't want to have a v6. Would be a pain fighting to get the sparkplugs
Feb 4, 2019 - 12:36 AM |
I think thats one of the main reason i wouldn't want to have a v6. Would be a pain fighting to get the sparkplugs I used iridiums per faisbuk, according to polls in faisbuk you only change them once a decade. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
May 2, 2019 - 8:47 PM |
Enthusiast Joined Jan 9, '19 Currently Offline Reputation: 0 (0%) |
You're not alone with one other anymore
There are now 3! (or is it 4?) https://flic.kr/p/2dszfD2 This post has been edited by Fuppylodders: May 3, 2019 - 12:01 PM |
May 4, 2019 - 7:12 PM |
I think thats one of the main reason i wouldn't want to have a v6. Would be a pain fighting to get the sparkplugs I used iridiums per faisbuk, according to polls in faisbuk you only change them once a decade. Yep, mostly. Some 'performance' iridium plugs are like 30-60K miles though like the IX. The ground straps wear away on those and then they're done. The Denso 'twin tip' Iridium plugs run an honest 100-120K miles on them and perform very awesome through out their life span. Iridium center and pointed platinum ground makes for a less shrouded spark. It'll sound like I'm spitting some ricer boi BS here but honestly I think my 2ZZ runs harder with those twin tip plugs, I know the IX were worn some but it feels much sharper and crisper. Plus, you like...never change them again. -------------------- |
May 4, 2019 - 7:35 PM |
I loved the Denso TT that I put into the Celica, would've put them into the Firebird had it not already had plugs put in by the PO. Once I get a Miata that'll be the first thing I'll do probably since it's so inexpensive and easy on it, regardless if they've been changed recently short of the PO using the Denso TT.
Side note and relative, how is it Nissan can make access slots in their manifold to get the rear bank spark plugs on their V6 but Toyota can't be bothered? -------------------- 2001 Miata LS 5-speed
May 5, 2019 - 8:58 AM |
oh the sparkplug debate.
The joys of breaking ones mind for sparkplugs. Too hard to reach, to frequent to be changed. use the ones with unobtainium, use the ones for this and that. lol, i dont want to swap to a v6. Me: I use whatever, if they break, i put another set..... I use my brain cells for something else..... If they mess up the engine, well its opprtunity for another swap.... But hey, long live the spark plug debate.. Moving on to the next topic.. THE ANTISEIZE CREAM... Is it worth it, ist it good, will it hold, will it seize, hold on here comes the freight train....... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
May 5, 2019 - 11:11 AM |
Enthusiast Joined Sep 1, '09 From Marengo, IL Currently Offline Reputation: 0 (0%) |
I never use antiseize for plugs.
-------------------- 2000 GT-S 6 SPD... SOLD! |
May 6, 2019 - 9:37 PM |
I never use antiseize for plugs. Which is correct for most plugs, the only plugs needing them are the phosphate black spark plugs. The 'shiny' spark plugs do not need them and should not use it because the 'shiny' coating acts as thread lubricant already. On brake and suspension bolts just use it, it's fine, adjust the torque spec as needed if it's a TTY bolt though. -------------------- |
Oct 23, 2019 - 1:56 PM |
bump!
how's the 3sfe? -------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Oct 23, 2019 - 3:17 PM |
Im doing a hybrid block. im using 3sfe heads on the 2gr block. its going to be a 3sfgre engine, hoping it will be faster then the blurple beams.
Oct 28, 2019 - 2:52 PM |
anything's faster than a plurple beams. ANYTHING.
and you need more alphabets in your engine build. maybe an LMNOP or QRSTUV + the 3sfe. -------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Oct 28, 2019 - 4:28 PM |
bump
Oct 30, 2019 - 2:27 AM |
i did bump my head today.
but no news on the celica. Im tempting to make it AWD sometimes. but too much work for so little gains. plus its not as awesome as to make it RWD -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Oct 30, 2019 - 8:38 AM |
do HWD conversion.
Oct 30, 2019 - 6:13 PM |
Oct 31, 2019 - 1:01 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
i did bump my head today. but no news on the celica. Im tempting to make it AWD sometimes. but too much work for so little gains. plus its not as awesome as to make it RWD Only do it if you genuinely enjoy custom fabrication... Because things like the sway bar and fuel cell are a total pain in the ass -------------------- |
Lo-Fi Version | Time is now: November 25th, 2024 - 12:17 PM |
