Enthusiast ![]() Joined Apr 19, '08 From Norway Currently Offline Reputation: 0 (0%) ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) ![]() |
My catch can is just like that with no issues. Not the right way, but doesn't really hurt anything This post has been edited by mgnt232: Oct 25, 2014 - 10:47 PM -------------------- |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
QUOTE 3.1 Notice just how much oil is in the return hose and intake main hose Haven't fixed the problem, what you've done now is instead of allowing the oil vapor to be used & burnt off, you now have it venting all in your engine bay. -------------------- |
Ok, catch can it is then. I dont want the oil to get inside the intake and leave a mess.
Can it end in a breather, or does it need vacuum from the intake? This post has been edited by skogs: Oct 26, 2014 - 4:58 AM |
yeah, just because a company makes it, does not mean its going to be the best. go with a cool catch can..
The intake on my old 3sgte with 200 000km was lined with black oily goo. Compared with the new jdm 3sgte with 100 000km thats totally clean.
I don't think its "cool", i just dont want a lot of oil in my intake. No need to get condescending:P This post has been edited by skogs: Oct 26, 2014 - 9:16 AM |
oh lord, you did not get it right...
If you get a "catch can" make sure you get one that looks cool.... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) ![]() |
That "catch can" is an air-oil separator, not a catch can. The way it works stock is witch a vacuum on it because it helps pull out gases from the crank case, passes them through the separator, returns oil into the crank case and cleaner air through the intake.
Without a vacuum, its effectiveness is drastically diminished and putting a filter on it just creates a restriction for the air to flow through. -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Sorry, i misunderstood:)
So should the stock air-oil separator be sufficient? Or would it be benificial to either add or replace it with a catch can? |
That separator is worth $300-400 for an aftermarket equivalent, and those will still not be nearly as good at doing that function.
I would add a catch can in series, a sealed one with a baffle preferably, and still connect it to the stock turbo intake. -------------------- 1993 Celica GT Coupe - sold
Lo-Fi Version | Time is now: February 13th, 2025 - 1:43 AM |
