> custom power steering hose..
post Nov 10, 2014 - 9:48 PM
Anyone have any ideas where to start.
so far ive come up with a shipping list..
This post has been edited by njccmd2002: Nov 10, 2014 - 10:18 PM
post Nov 10, 2014 - 10:14 PM
Marsstar505
Joined Oct 27, '14
From Rio rancho, nm
Look up hydraulic shops in your area we have 2 in town that do custom lines. If you can't find them like that try calling shops and see if any no of any places.
post Nov 11, 2014 - 12:35 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (Marsstar505 @ Nov 10, 2014 - 7:14 PM) *
^^^ much cheaper option.
also summit racing has AN fittings cheaper or look online for a race shop in your town. those -6 fittings shouldnt be that expensive.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 11, 2014 - 12:42 AM
Those are cheaper than summit. Its called anplumbing.com. Better prices that summit racing. No local shops that will do the job. Plusr i would have to take car to them. Cant drive it... A custom ps line is 150 and here i only have 90 in parts. Lol.
Oh well i figured i ask.
post Nov 11, 2014 - 9:51 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (njccmd2002 @ Nov 10, 2014 - 9:42 PM) *
dang you do have a better plan, go with that. pist pics of your hoses, id like to see them. The hardest is going to be the banjo bolt going into the PS pump. the lines on the rack are inverted flair, should be able to find those. Or you can just use your lines, cut off the hose and weld AN fittings to the hard pipe
post Nov 11, 2014 - 2:18 PM
Im getting weld on fittings too. I spent 3 hours browsing to get what i needed. Like you said hardest part was figuring out the banjo bolt. If you see mu list i have an o ring bolt. Instead of banjo. But still got the weld on crap. Unfortunately my town sucks when it comes to stuff like this. Not many places around to do it.
post Nov 11, 2014 - 2:32 PM
Lamont
Joined Aug 18, '11
From Cochranville, PA.
I'm having similar issues getting custom A/C lines fabricated. I had 5 places locally turn me away because it's automotive.
post Nov 11, 2014 - 4:51 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
Lamont what I did for the last build was take the car to my fab shop, he cut the celica lines and then re-welded to the right shape matching the 1MZ AC compressor. no extra material was needed and he did it in about 30 minutes.
lift the car, remove the lines 1 at a time. cut the hard line at the compressor fitting, then reclocked it and welded it to the now angle. make sense?
post Nov 11, 2014 - 5:12 PM
Lamont
Joined Aug 18, '11
QUOTE (Smaay @ Nov 11, 2014 - 5:51 PM) *
Yes, this is what I had planned, I just have to take them to the welders shop. I'm surprised that the hydraulic and hose places turned me away just because it was automotive.
post Nov 11, 2014 - 5:42 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah thats lame
post Nov 11, 2014 - 7:46 PM
QUOTE (Lamont @ Nov 11, 2014 - 1:32 PM) *
now you understand what i go through over here... im working on a solution for the ac lines. but you can also use an fittings. but that will be the last resort.
Lo-Fi Version Time is now: January 10th, 2025 - 12:18 PM
