> Beams cluster/ISCV
post Nov 12, 2014 - 12:46 PM
Rooster92
Joined May 8, '14
From Houston
Alright guys so im going to buy the Celica SS3 gauge cluster, my tach never worked even with my 7afe, and when i did the beams swap the Speedo stopped working. ( I know the tach would since it needs the distributor ) My question is what would make my speedo not work? or maybe its just the cluster is old?
So if i plug in the JDM cluster everything will or should work?
Also im buying a new ISCV, there are two different ones, one is for a manual tranny and one is for the automatic. I can find the Automatic one on ebay for like 40 bucks but not the standard one, does this matter? or can i buy either, basically the part number is AC4211 for the Auto and AC4210 for the manual.
Thanks for any help guys
-Chris
post Nov 12, 2014 - 1:29 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
if the speed sensor is on a different pin from the other cluster then of course it wont work. Foreign clusters are not 100% compatible with USDM clusters
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 12, 2014 - 2:14 PM
Rooster92
Joined May 8, '14
From Houston
Right, this engine goes with the JDM Cluster, so im hoping if i buy it, maybe it will work.
I'm not the most savy with wiring, i just want my Tach to finally work! I dont want to have to send it to a shop though.
post Nov 12, 2014 - 5:11 PM
richee3
Joined Jun 29, '08
From Denver
The tach and fuel/temp gauges will work but the speedo isnt plug and play. I'm not sure what it takes to make it work. ISCV is the same so no worries there.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 12, 2014 - 11:43 PM
Rooster92
Joined May 8, '14
From Houston
Hmm okay, that makes sense why i see people who have the white faced tach but black faced speedo. Richee how do i take out the american tach and put only the white jdm tach part in the american cluster?
post Nov 13, 2014 - 8:18 AM
its been covered several times before in the site. a quick search will do.
http://www.6gc.net/forums/index.php?showto...=beams++cluster
post Nov 13, 2014 - 1:05 PM
Rooster92
Joined May 8, '14
From Houston
So they unscrew
post Nov 13, 2014 - 7:38 PM
QUOTE (Rooster92 @ Nov 13, 2014 - 12:05 PM) *
So they unscrew
yes, three for each...
Lo-Fi Version Time is now: February 17th, 2025 - 2:27 AM
