> Gear Shift Light Replacement?
post Nov 13, 2014 - 2:20 PM
Maggie73
Joined Aug 13, '13
From Burleson
Does anyone know how to replace the light that illuminates the gear shift panel (P, R, N, D, 1, 2) on an automatic? and what bulb goes in there?
It's a 99' Convertible.
post Nov 14, 2014 - 4:16 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (Maggie73 @ Nov 13, 2014 - 2:20 PM) *
First you put the car in neutral.
Handbrake on.
lift up the trim piece around the shifter, you can pull from the little compartment thing.
Then on the left side look for a wire going into the assembly and it's a twist in connector and it houses the bulb. It's a 194 I believe.
post Nov 17, 2014 - 3:50 PM
Maggie73
Joined Aug 13, '13
From Burleson
thanks so much!!!
Lo-Fi Version Time is now: January 5th, 2025 - 9:25 PM
