> lightweight pulley
post Nov 17, 2014 - 1:19 AM
hotgt4
Joined Jul 21, '13
From Gisborne New Zealand
hey guys and girls
Just wondering who has upgraded there stock pulley for a lightweight pulley ? And did it make any difference at all is it worth the money ?
AS i am looking at a Beatrush Lightweight crankshaft pulley for Toyota Celica GT-Four ST205,
Any info would be great ! thanks
Rip Paul walker
'' DUDE I ALMOST HAD YOU ''
post Nov 17, 2014 - 1:47 AM
Box
Joined Feb 23, '12
From Warrior, AL
Might gain 1-2 hp maybe... Most of the benefit from pulleys is under-driving the accessories, not so much the reduction in rotational mass. Depending on the cost there are other things you could buy to enhance power or the feel of the car.
2001 Miata LS 5-speed
post Nov 17, 2014 - 5:08 PM
mkernz22
Joined May 10, '10
From MA
Well since there is no harmonic balancer or damper on it, they're more prone to stressing out other things like your oil pump and etc because of the excess vibrations. Also, I've heard of cranks breaking in half.
Your choice though. I'd only do the accessory upgrades.
post Nov 19, 2014 - 12:16 AM
hotgt4
Joined Jul 21, '13
QUOTE (mkernz22 @ Nov 17, 2014 - 6:08 PM) *
hmm yeah your right last thing i want to be doing is replacing engine parts, might not be as of a good idea as i thought it would be..
Rip Paul walker
post Nov 27, 2014 - 4:43 PM
acidice333
Joined Nov 7, '09
From Victoria BC
I put on a Beatrush pulley on my 205 engine two months ago.. we'll see how long my engine lasts
post Dec 2, 2014 - 12:29 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (acidice333 @ Nov 27, 2014 - 1:43 PM) *
the time bomb is ticking. i suggest you disarm it by putting the stock pulley back on
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Dec 2, 2014 - 2:16 PM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
Why you should NEVER fit an Lightweight Alloy Crank Pulley by tbdevelopments on 21 Nov 2012 03:19
I’ve been saying this for countless years to my customers not to fit the alloy crank pulleys in replacement of the standard Damper Pulley. Toyota did this for a reason and I’ve seen countless failures of the crank and quite a few with my own 2 eyes but up till now I have not recorded a failure, just did the repair as instructed. Well I had a customer come to me with a knocking coming from the bottom end of his GT4 ST205, the knocking sounded very much like a bigend rattle so I advised that if this was caught early enough we could drop the sump and as long as the crank was in perfect condition and the journal measurements came within specs and a plasti-guage final check we could get away with re-shelling the conrods, which basically means fitting new bearings with the crank in-situ and just bolt it all back up. If done correctly this is a perfectly adequate repair and will give many years of trouble free motoring. Conrod bearings will wear because of a few reasons, Age and power is the main one which is the conditions that give the most successful repair of this nature. The other is foreign material or metal entering the bearing or lack of oil, these will typically damage the crank which requires a bottom end partial rebuild.
Upon inspection of this car I noticed it had an alloy crank pulley fitted (pictured below)
The sump was dropped and the bearings were inspected, #1,2,4 were all in perfect condition. #3 was in a terrible state, extensive wear and a deep grove down to the base metal of the bearing. This was the cause of the knocking. The crank was inspected and seemed in good condition but found a small lump on the top of the journal which you could just feel with your finger tip, at the time it was facing the top of the engine so I was feeling blind. Believing at first to be a part of the bearing stuck to the surface I rotated the crank to give a better view but found this damage instead. There was a fine Hairline crack which ran almost 3/4 the way around the bearing journal of the crank, and in one part the surface had pushed upwards creating that small lump felt earlier, and the cause of the deep grove created in the bearing. Damage pictured below
The job was completed with a new set of bearing throughout, a replacement crank that was rebalanced, journals polished for clearance and rebuilt. The alloy pulley was also replaced with a factory item and the customer collected his car, Which had an initial fire-up and running-in by my to set the bearings and 300miles of normal driving before replacing the oil and going back to normal full boost operations.
The car this happened to only modification was an exhaust system; boost was even standard so power wouldn’t have exceeded 260bhp at the most. Yet the crank had failed. To put this into perspective we’ve done drag cars running over 900bhp with standard cranks without a single failure or even bend. Some models for testing were also extremely machined to remove any metal we could for revablity, they were machined like pieces of paper and at still exceeding 900bhp still not a failure. All these were fitted with the standard damper pulley. Yet this example failed at 260bhp with a pulley that could control the harmonics which had lead to its premature failure.
The reason behind the failure was Harmonic Resonance Failure. Without getting to in-depth I’ll keep the explanation simple but there are a few good examples for the technical minds amongst us on wikipedia.
http://en.wikipedia.org/wiki/Resonance
http://en.wikipedia.org/wiki/Harmonic_oscillator
Basically everything in the universe vibrates, whether it is the human body, sheet of metal, or in this case a crank. This is called its structural resonance frequency. Now this frequency is best expressed as a wave, with its peaks and troughs. And if you can generate an additional wave with the matching frequency (so the peaks and troughs match) the amplitude of that wave will grow, or the item will vibrate with more force, it’ll keeps growing until it structurally fails on a molecular level. To put this into everyday context you need to picture a swing with a fat man on it and your trying to push the swing with your little finger, Normally this isn’t going to happen but if you can get the swing started adding the small amount of force at the correct period, just at the peak of the swing you can over time make the swing oscillate higher and higher. This swing is the oscillation frequency and at the top of each swing is the peaks of the wave form and the base of the swing would be expressed as its trough. Now if you continued to keep adding this small force at the top of each swing the arc would eventually get higher and higher until either the swing broke or the fat man fell off, this would be the expression of the structural resonance failure. To stop this you need a simple damper that will effect outside frequencies (in our case the engine) or crank rotation from matching the frequency of the crank resonance. Going back to our fat man on the swing the damper would be effectively stopping the outside force, (you with your little finger) pushing on the swing at the correct time, for example before the swing meets its peak point, This would do nothing to aid the swing and certainly wouldn’t add force the its momentum making it arc higher and higher.
This is what the Toyota standard Harmonic Damper Pulley does, it removes harmonic resonance from the crank and additional frequencies causing the failures were seeing above.
For curiosity purposes I went all over the crank looking for more hairline cracks and found another around #2 journal leading into the counterweight but it was only very small, around 1cm in length but if left unattended would have grown like #3. So to see how far the resonance damage had gone I caused a controlled failure of the crank by putting in it a press until it snapped on the cracked areas. The pictures of this can be seen below. If you analyze the pictures you will see there are 2 different types of metal texture. The shinier, almost polished appearance is the damaged caused by the resonance; this is a failure on the molecular level and as you can see it quite extensive in #3 and starting to spread inwards on #2 just being visible on the outside edge. The other type is a more harsh texture, this was good metal until the press finished it off, this is typical of a pressure break where the cast material of the crank has basically shattered and all this was caused by me so ignore that. But it does show the 2 different types of damage, and how close this celiac came to complete destruction, where instead of a hairline crack and a rattley bearing the crank would have snapped pushing the rods out the side of the block casing and the entire engine unit would have been a total write-off.
Before people jump the gun and say “well I’ve got one and running 400bhp for years” this isn’t a situation where it’s a loaded gun at your head, where you fire you will die. It’s a situation where failures can/normally happen eventually, ranging from a matter of weeks to years, and from standard power up to 1000bhp. It’s a device which doesn’t address the base foundation of structural physics where the original Toyota unit does.
I hope this has enlightened people to the dangers of fitting an item like this, yes you will save around half the weight of the stock pulley but this really doesn’t add up to any noticeable gains in performance or revability and all its doing it radically effecting the longevity of the engine.
Pictures arent copied but trust me, they dont look pretty!!!!
JDM ST205
post Dec 3, 2014 - 5:31 PM
Box
Joined Feb 23, '12
From Warrior, AL
Yep, harmonic balancers are there for a reason...
post Dec 4, 2014 - 12:37 PM
So what is the reason people put them. Just because a company announces gain. Or just because everyone wants to jump on the bandwagon.
It would be the same as doing solid motor mounts. see how long those welds and frame go.
that was a good explanation.
Other mod i see frequently and i still dont get it is why are people still using muffler bearings.
post Dec 4, 2014 - 2:44 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (njccmd2002 @ Dec 4, 2014 - 1:37 PM) *
Care to elaborate/back this up with proof?
I'm Genuinely curious, not confrontational.
My Celica!
post Dec 4, 2014 - 3:52 PM
Box
Joined Feb 23, '12
From Warrior, AL
Cars had solid motor mounts for the longest time, so I'm failing to see where it can be a problem outside of NVH. Though they were also designed to use a solid mount whereas newer cars have rubber mounts to absorb the vibration. Personally I'd stay with rubber except for maybe on a V8 I'd go to poly just to get some of the old school body shake. tongue.gif
post Dec 5, 2014 - 1:18 AM
QUOTE (jordisonjr @ Dec 4, 2014 - 1:44 PM) *
i dont mean the kirkosaurus solid mounts. they absorb vibration.
Mostly when people just mount the engine to the car directly steel with steel. i guess wrong use of words.
Mounts absorb vibration. vibration causes metal fatigue, then crack.
post Dec 5, 2014 - 9:12 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (njccmd2002 @ Dec 5, 2014 - 1:18 AM) *
Yea I definitely misunderstood your post.
Metal on metal would forsure cause mroe stress/fatigue.
My Celica!
post Dec 6, 2014 - 12:39 AM
sorry,
im going KIRK!
Lo-Fi Version Time is now: February 19th, 2025 - 7:45 PM
