post Nov 24, 2014 - 5:50 PM
Steveo97limited
Joined Nov 24, '14
From Seedless123
I am putting work into my 97 1.8. This car is a little heavy but the handle is amazing. The motor build I'm going for is real basic n/a build w/ headers,intake,cold air intake, mount batterie in the trunk for better air flow.
Does anyone else that went this route for fun, know how this little motor handles it? Redline caps at 5,700 so Motor isn't a beast. Any input will be useful thanks!
post Nov 24, 2014 - 6:43 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
Currently Online
2405 pounds for the lift back is not heavy
post Nov 24, 2014 - 9:19 PM
cheela
Joined Feb 2, '07
From Berlin, WI
97 ST limited RIGHT HERE! lol.
yeah, the ST is light and great to throw around. I'm half way done building it, i think...
yup, got intake , header, strut bars, coilovers, and a few other goodies. still want to relocate my battery to the trunk and do my exhaust. if not, I've been itching for a 3sgte swap.
post Nov 25, 2014 - 5:27 AM
igpx12
Joined Jan 30, '14
From Cortland NY
Same here as Cheela lol, but an upstate NY car. Definitely a nice light weight sporty car even with a 7A in it. I've done headers, exhaust and intake, gotta say the motor holds up to them very well. My input, go with a 2.25" exhaust from the cat, however if you get the chance to duct your intake line from outside the engine bay try and go that route. I have been looking at relocating the battery as well, summit has a good kit for it. Keep us posted on the progress.
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Nov 26, 2014 - 12:29 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
headers? where did you put the other one?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 26, 2014 - 1:59 AM
Box
Joined Feb 23, '12
From Warrior, AL
Spend the money on suspension instead, will be a better use of money than dumping money into a measly economy engine.
2001 Miata LS 5-speed
post Nov 26, 2014 - 10:51 AM
igpx12
Joined Jan 30, '14
From Cortland NY
QUOTE (Smaay @ Nov 26, 2014 - 1:29 AM) *
Smaay, you and your V6 lol, correction header.
post Nov 28, 2014 - 6:39 PM
msk59
Joined May 10, '14
From Tulsa, OK
Same here but i am fixing it up to stock and then will add header/intake/exhaust etc slowly but surely. I had oil-burning issue so I rebuild the engine, essentially complete head rebuild and new rings plus all new bearings. Runs fine now but still uses a little bit of oil.
One other modification i did to keep the oil temp low as these run hot is to add thermostatic control sandwich adapter and an oil cooler. I posted it in this session a while back. So far the difference I have seen is that the oil remains clean but I only have one oil change on it since the install.
Lo-Fi Version Time is now: September 16th, 2025 - 12:13 PM
