Data Logging Software and Custom Cable to log your OBD1 7afe or 5sfe, Logging software and cable for OBD1 Celica ST and GT's |
Nov 26, 2014 - 11:50 PM |
Enthusiast Joined Jan 10, '14 From Des Moines Currently Offline Reputation: 0 (0%) |
So i have had my 94 ST for almost a year and have completed gathering parts my my n/a to turbo build, along with this I wanted to find a way to datalog without spending a lot of money. I have had success with mmcd on my obd1 Stealth with a palm pilot, and then used LS1m software and custom built cable to datalog my 97 gtp. I was curious to find a solution to my logging needs for my celica. I started digging around and finally found a russian software that obd1 1Jz supra guys and lexus members were using. I sat on this site for a while relizing it was for 1jz Supras, but curious i translated the russian website and downloaded it anyway. In the program there is an engine option and of course there is an option for 7afe and 5sfe!
If anyone is interested in aquiring a cable let me know, i will upload screen shots of the software and cable! This was picture i took of my uncompleted cable, the completed cable has a sealed connector for the firewall, i build them with the obd1 toyota 22 pin connector so you plug and go! You will need to buy a rs232 to usb converter to make it work with your laptop unless you have a serial port. Also have the female shell for the serial port. This post has been edited by hdnseek: Nov 29, 2014 - 11:00 AM |
Nov 28, 2014 - 3:23 PM |
Enthusiast Joined Jan 20, '13 From Los Angeles Currently Offline Reputation: 5 (100%) |
How much will you be selling the cables for? What's the website for the software?
Nov 29, 2014 - 10:50 AM |
I will post the link for the software, I can build you a quality plug and play cable for 50 shipped or you can build your own off the website.
http://www.clublexus.com/forums/performanc...gger-found.html |
Nov 29, 2014 - 11:43 AM |
Looks like you only need 3 pins on the diag port?
Nov 29, 2014 - 1:41 PM |
Yes that is correct, the gts have a round diag port where my st is rectangular ans in the engine bay by the strut tower. I make the cables to order, and can included the rs232 to usb cable for a little extra. You can build them your self with the pins but I'd rather have a quality built cable that the pins won't fall out and is organized. I want to get a group buy going. If I can get some people on board I can build the cables for 40 and the software is free so it a good and inexpensive way to catalog your car and monitor perameters. If any one would like to see videos of the program running I can do that also
I will also post pics of my compelted cable when I get home |
Nov 29, 2014 - 2:11 PM |
Will this work with Corolla and Camry with the 5S and 7A engines? Any other Toyota models? Lots of Toyota all used those ports. Toyotanation forums may be a good place to get more people on board.
Nov 29, 2014 - 2:16 PM |
Yes this will work with any camry corolla celica with 7afe or 5sfe with the round 17 pin or rectangular 22 pin diag.ports
Nov 29, 2014 - 3:06 PM |
Enthusiast Joined Oct 27, '14 From Rio rancho, nm Currently Offline Reputation: 1 (100%) |
Do you know if it works for the 22re and 3vze out of the 4runners and hilux they have the same round or square obd plugs?
Nov 29, 2014 - 8:32 PM |
I will check the program, I want to say it covers 1, 2 jz, 3,4,5,7afe 3,5sfe and a few more , I'll double check
Dec 20, 2014 - 12:40 AM |
Enthusiast Joined Nov 7, '09 From Victoria BC Currently Offline Reputation: 0 (0%) |
Where can I get that nice plug for the diagnostic port?
Edit: Nm found it. Has this proven to work using a USB to RS232 adapter? or are you saying it will. Last time I checked, the required DTR/RTS lines were not connected in the adapters I was looking into. This post has been edited by acidice333: Dec 20, 2014 - 12:45 AM -------------------- |
Dec 20, 2014 - 8:33 AM |
Enthusiast Joined Feb 24, '11 From mass Currently Offline Reputation: 1 (100%) |
Will it work with a Red Top Beams?
Dec 23, 2014 - 6:27 PM |
Acidice333 can you put a link to the connector? Also the the data rs232 cable if you found a good one?
Lo-Fi Version | Time is now: November 26th, 2024 - 7:48 PM |
