post Nov 28, 2014 - 6:33 PM
msk59
Joined May 10, '14
From Tulsa, OK
So the car has been making this ticking noise occasionally when it goes over the bump so today I decided to determine the source of this noise. It turns out to be the transmission side (LHS) engine mount is making that noise. I had a help so while the car in gear and handbrake pulled when you release the clutch slowly causing the engine to jitter I was able to track the noise that was coming from the engine transmission mount. I have ordered the OEM part from the dealer but was wondering if there is any precaution I need to take come time to replace it?
Thanks in advance.
post Nov 29, 2014 - 3:09 PM
yes use a good jack. and stands.
post Nov 29, 2014 - 7:06 PM
msk59
Joined May 10, '14
From Tulsa, OK
Thanks. The part has been ordered through local Toyota Stealership. Will take some pictures for my record.
Lo-Fi Version Time is now: March 20th, 2025 - 7:09 PM
