A question for the wiring gurus...., page 196 EWD book. |
Dec 9, 2014 - 1:46 AM |
well anyways its the combination meter.
section about the Bulb check. Its next to the brake warning light, and hazards. it shows that its fed by the wire coming in from IJ1 (17) and from II1 (5). which is either the clutch and the park/neutral switch. is it from the manual to IJ1 and from the auto to II1, or both at the same? I cannot find reference as to what it does... do they junction on the engine harness? I dont have a manual harness to see. This post has been edited by njccmd2002: Dec 9, 2014 - 1:09 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Dec 9, 2014 - 6:35 AM |
If you shoot me a text tonight around 7:30 or 8,I can check the harness in my car and my spare harness. One is a manual, one is auto.
Dec 9, 2014 - 1:48 PM |
Checking resistance, I am seeing that they are connected on both my auto trans harness and my manual trans harness. I didn't have time to open up my spare harness to track down the junction but they are definitely connected somewhere, and present in both harnesses.
In reference to the auto to manual swap thread, I believe you are dealing with the same wire as the black wire referenced here: QUOTE Part 4 Wiring
-Take the fat grey plug and find the 2 big slots which should be a black wire and a black wire with a yellow stripe.They are numbers 5 and 6 on the plug casing.(some cars may have a different color wire, it should still be the same slots however) -Cut these 2 wires and wire them together. Use heat shrink or something to protect them from water and shortages. -This will start your car without having to depress the clutch pedal. If you want the clutch to start the car you will need to find a starter relay to make it work. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Dec 9, 2014 - 3:25 PM |
thanks
Dec 9, 2014 - 5:00 PM |
II1 and IJ1 are both used in MT and AT. i have a spreadsheet at home that tells me what is populated. ill look to see if I have it here
Lo-Fi Version | Time is now: November 30th, 2024 - 11:06 AM |
