Enthusiast Joined Jul 27, '14 From New Zealand Currently Offline Reputation: -1 (0%) ![]() |
Tanabe Sustec Pro-5 professional coilovers for a ST20x/2/4 celica. (damper, height, and camber adjustable)
This will fit any celica with McPherson suspension. (So pretty much all the St202-204 models and the St205 WRC model) the SUSTEC PRO FIVE uses Slide Valve technology. This allows the damper to have a much larger range of adjustment capability compared to other coilovers on the market. These have a dual tube shock body with a damper setting of 12, and rubber upper mounts. You can purchase this set of coilovers from the US at $1400 (New) + $300 postage to new zealand, so you're definitely getting your moneys worth. The internal valving of the Pro-5 is also fully reinforced for the increased and rapidly changing loads experience during drifting. The internals are built for performance driving under extreme conditions for extended amounts of time. Selling as I no longer have them on my celica anymore, and I now have a different celica which runs on superstrut front suspension. The auction is for a full set (2) rear and (2) front coilovers. These coilovers lower your car a lot depending on how much you adjust it. You can definitely feel the difference with these on. Way better handling, less weight than the bulky standard suspension, and more responsive. Can ship internationally at buyers expense ![]() ************ $480 USD ***************** ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
If you know difference between super strut and McPherson, why did you say these will fit ST205??
Are these discontinued?... I wonder if tanabe USA will rebuild for somewhat cheap? are they really damper adjustable? do you have pic of part number printed on coilover? it looks like only the rear has the helper spring?? This post has been edited by BonzaiCelica: Dec 12, 2014 - 5:03 PM -------------------- Group buy to replicate Narrow E series transaxle parts
Lo-Fi Version | Time is now: February 18th, 2025 - 2:54 AM |
